低价供应石英纤维布
石英纤维--Quartz Fiber
产品简介:Introduction
Glassfiber  Quartz Fiber
HPQY is produced by drawing fiber (9 micron or 14 micron) from high purity (SiO2> 99.95%; exclusive of binder) quartz rods.  So quartz fiber has many superb properties : high purity, high temperature resistance, ablation resistance, low heat-conductionAnti-thermal Shocks, excellent dielectrical property and chemical stability. Primarily used as materials of electric insulationheat insulation, composite reinforcement , etc. Typical products are aircraft nose, radome , rocket tailpipe nozzle and ablative material of space vehicle,etc. Otherwise some other quartz fiber products are available , such as fabric, tape,chopped strands, unwoven roving, rope,wool and braided sleeving .
高纯石英纤维(SiO2> 99.95%)是由高纯石英棒熔融拉制而成的连续长纤维。其具有高纯度、耐高温、耐烧蚀、低导热、抗热震、优良的介电性能和良好的化学稳定性等。主要用作电绝缘材料、隔热材料和复合材料的增强体。用于制造飞机机头、雷达罩、火箭的尾喷管、空间航天器的烧蚀材料等。另我们还可根据客户需要提供其他石英纤维产品,诸如布、带、短切纤维、无捻粗纱、绳、棉、编织套管等。
技术指标:Technical data
项目items
参数 data
纯度 purity %
SiO2≥99.95
密度density g/m3
2.2
拉伸强度tensile strength GPa
3.6
弹性模量elastic modulusGPa
78
硬度 hardness
6-7
耐温thermal°C
1200
软化点softening point°C
1730
热膨胀系数
thermal expansivity°Cֿ¹
轴向axial direction5.4×10ֿ7
径向radial direction5.4×10ֿ7
电阻率resistivityΩ*cm
20°C10 19
800°C2*10 17
介电常数permittivity
3.78
损耗角正切值dissipation factor
0.0001
注:1.可根据客户要求提供特殊规格产品。2.以上数据仅供参考。
Mark: 1.Special product could be available based on customers' requirements .2.Reference data only, not for technical specifications.
天津市中天俊达玻璃纤维制品有限公司 > 铝产品 > 低价供应石英纤维布
