主营:短切毡,方格布,缝编毡,石英纤维
天津 天津
2.1元/平方米(大量采购价格面议)
玻璃钢表面毡Surfacing Tissue Mat
产品简介:Introduction
Fiberglass surfacing tissue is used in the surface layers for FRP products.
玻璃纤维表面毡用在玻璃钢产品的表层。
产品特点:Features
Characteristics
· Uniform fiber dispersion 纤维分散性好
· Smooth surface 平滑表面
· Low binder content 粘结剂含量低
· Fast resin impregnation 树脂浸透速度快
· Good mould obedience 覆膜性好
· Significantly improves the strength of FRP surface layers有效提高FRP表层强度
· Strong impact resistance很强的耐冲刷性
· Excellent uniformity of surface毡面均匀
· Good covering of the texture of under layers贴附性好
· Good corrosion resistance防腐性能优
技术指标:Technical data
Item |
Unit |
Type |
MFS20 |
MFS30 |
MFS40 |
MFS50 |
MFS60 |
Filament Diameter |
µm |
12 ± 1 |
Weight |
g/m2 |
20 |
30 |
40 |
50 |
60 |
Binder Content |
6 - 9 |
Soaking Time (2 layers) |
S |
8 |
10 |
13 |
16 |
20 |
Tensile Strength MD |
N/50mm |
35 |
40 |
50 |
60 |
70 |
Moisture Content |
< 0.5 |
Standard |
Width x |
m x m |
1 x 400 |
Roll |
mm |
< 360 |
Paper core |
mm |
76 |
Non-Standard |
Width |
mm |
100, 150, 200 and 250 (± 3) |
Roll |
mm |
< 360 |
注:1.可根据客户要求提供特殊规格产品。2.以上数据仅供参考。 Mark: 1.Special product could be available based on customers' requirements .2.Reference data only, not for technical specifications. |
