主营:铝板,铝卷,花纹铝板,铝瓦,压型铝板,铝皮
山东 济南
面议/吨(大量采购价格面议)
合金铝卷在现代建筑装饰领域有较广泛的应用价值,合金铝卷优越的产品性能被越来越多的朋友认可。为了更好的利用合金铝卷,简单介绍合金铝卷的防氧化措施。
Aluminum alloy coil has a wide range of applications in the field of modern architectural decoration, aluminum alloy coil superior product performance has been recognized by more and more friends. In order to make better use of aluminum alloy coil, the oxidation resistance measures of aluminum alloy coil are introduced briefly.
铝卷生产厂家放置的空间要加强空气干燥的管理,确保压缩空气中无水。加强轧制油的管理,其含水量控制在0.04%以下。铝箔卷的包装应采用密封包装,同时每卷应放入适量的干燥剂。
Aluminum coil manufacturers to place the space to strengthen the management of air drying, to ensure that the compressed air without water. To strengthen the management of rolling oil, its moisture content is controlled below 0.04%. The aluminum foil coil should be packed in a sealed package, and each coil should be placed with an appropriate amount of desiccant.
合金铝卷可以分为冷轧和热轧,主要区别是以阳较氧化为区别,热轧铝卷可以做阳较氧化.
Aluminum alloy coil can be divided into cold rolling and hot rolling, the main difference is the difference between anodic oxidation, hot rolled aluminum coil can be anodized
冷轧铝卷和热轧铝卷用途不同,冷轧铝卷多用于模具类,热轧铝卷适合冲压拉伸方面.同样的材质由于制作工艺不同,它的物理性能相差很大.铝加工又被称为塑性成形,按铝材在变形过程中的受力与变形方式(应力-应变状态)分为:铸造、锻造、挤压、旋压、拉拔、轧制、成形加工(冷压、深冲)等加工方式
Cold rolling and hot rolling aluminum coil aluminum coil uses different cold-rolled aluminum coil used for the mold, hot rolled aluminum coil for stamping and drawing. The same material due to the different production processes, differ in its physical properties. The aluminum is also called plastic forming, in aluminum during deformation stress and deformation mode (the stress-strain state) is divided into: casting, forging, extruding, spinning, drawing, rolling, forming (cold pressing, deep drawing and other processing methods)
合金铝卷的包装箱的木轴、箱板的湿度不大于18%,包装铝卷的温度不大于45℃。由低温区运入温度高、湿度大的地区时,不要立即开启密封包装。车间、仓库房顶有漏雨、雪的地方不应放置铝卷。
