主营:喷砂机,抛丸机,抛光机,除尘箱,弹簧,聚氨酯设备
浙江 温州 龙湾区
68000元/台(大量采购价格面议)
本机特点 Features of this machine
1、间歇机大转盘间歇回转,小转盘自转。
1. otates intermittently and the small rotary table rotates automatically.
2、多工位连续式喷砂,效率高。
2. Multi station continuous sandblasting, high efficiency.
3、可根据工件的外形尺寸,调整每支喷头的位置。
3. The position of each spray gun can be adjusted according to the overall dimensions of the workpiece.
4、配有砂尘分离器,产品品质高,节约能耗。
4. Equipped with efficient sand dust separator, high product quality and energy saving.
5、采用PLC智能控制,除启动和急停外其它全部功能在触摸屏主页控制,控制界面为单一界面,工人能直观的进行操作,降低了本机对操作工人的使用要求。
5. PLC intelligent control is adopted, and all other functions except startup and emergency stop are controlled on the touch screen home page. The control interface is a single interface, so that workers can operate intuitively, reducing the use requirements of the machine for operators.
适用范围:适用于圆盘类,圆柱体及多边体的工件,外表喷砂批量处理,如工艺品,玻璃灯罩,手电筒,烤盘,发夹等。
Scope of application: It is applicable to disc, cylinder and polygon workpieces, and the surface is sandblasted for batch processing, such as handicrafts, glass lampshades, flashlights, baking pans, hairpins, etc.
