2986-401217-12山东
TEL 1181-000284-15 PCB ASS'Y SG-12700W
TEL 1181-000309-11 PCB ASSY MD1F-0
TEL 1181-000310-13 PCB ASSY WC1F-01A
TEL 1181-000317-14 PCB ASSY
TEL 1181-000336-13 PCB ASS'Y MC-31078B
TEL 1181-000337-16 PCB,ASSY MC-31049-2
TEL 1181-000566-11 PCB, ASSY MDIF-02A-A MOTOR DRIVER
TEL 1181-00175-16 BOARD 80-2050C
TEL 1181-00211-12 PCB ASSY
TEL 11810001 PCB, CP-8090A
TEL 1185-001021-11 TRAP, VF, INNER ASSY.
TEL 1185-003047-11 MANIFOLD UNIT ME (1058120B)
TEL 118500102013 TRAP, VF, BODY ASSY.
TEL 1187-000182-11 PCB MC-31023
TEL 1187-004746-11 BOARD CIRCUIT RE-8808 FURNACE
TEL 1187-005235-11 CABLE ASSY
TEL 1187-008494-11 TUBE ASSY G6-243*70.5 (SS)
TEL 1187-008496-11 TUBE ASSY G4-249-(S-2)
TEL 1187-017581-11 APC DRIVER PCB UN
TEL 1187-026762-11 FEMALE CONNECTOR..FVM -FC-19-6
TEL 1187-027-852-1 BAND
TEL 1187-027933-13 CO****OLLER UNIT
TEL 1187-028970-16 CO****OLLER UNIT
TEL 1187-030596-11 MANIFOLD, 8S-I-A7-W-S-1
TEL 1187-030879-12 HEATER, 2 1/H, VERTICAL
TEL 1187-040427-12 DRIVER, HF, AUTOSHUTTER
TEL 1187-041131-11 FLANGE END CAP ASSY, LPCVD REA
TEL 1187-042765-11 MANIFOLD, 8SN-R-A5-N-I-1
TEL 1187-043355-12 TUBE ASSY, G4-270
TEL 1187-094864-11 BURN OUT HEATER
TEL 1187-127327-11 OUTSIDE PIPE (P-N2) SUS 1187-127327-11 CTA
TEL 120008151 VALVE,SOL VT307V-5GS-01-F
TEL 1208-001150-11 INDEXER (35427030098)
TEL 121-188 BOARD STAGE TERMINAL
TEL 1280-001386-14 HOT CHUCK CO****OLLER
TEL 1286-009274-12 HARNESS 2 MOTOR
TEL 1287-002779-11 JOYSTICK ASSY 80 S/W
TEL 1287-004399-11 UNIT LCD DISPLAY 20S
TEL 1310-392519-11 INNER CUP SKIRT
TEL 1310-496523-16 BLOCK R
TEL 1310-497091-12 STOPPER (8)
TEL 1380-000970-11 MOTOR, C/S AXIS 60W
TEL 1380-001877-11 PLATE OVEN
TEL 1380-002028-11 DRIVER SERVO
TEL 1380-002030-11 DRIVER SERVO
TEL 1380-002052-11 MOTOR DRIVER
TEL 1380-002054-11 MOTOR DRIVER
TEL 1380-002285-11 CHEMICAL FILTER
TEL 1380-002712-11 PUMP.. SB-3SH-M-A
TEL 1380-100344-11 LENS UNIT (HLL302T1)
TEL 1380-100346-11 SENSOR LIGHT GUIDE
TEL 1380-100347-11 SENSOR BOARD INTENSITY
TEL 1380-100351-11 FUSE TEMP
TEL 1380-100355-11 ROTARY SOLENOID
TEL 1380-100389-11 HEATER FOR T H UNIT
TEL 1380-100514-11 DRIVE BELT IF-Y-22-0
TEL 1380-100535-11 PULLEY D(C/S Z BA
TEL 1380-100546-11 BELT
TEL 1380-100550-11 C/S CONNECTOR BAS
TEL 1380-100551-11 NUT
TEL 1380-100622-11 DRIVER SERVO
TEL 1380-100694-11 MOTOR, C/S AXIS 30W
TEL 1380-100840-11 REGULATOR
TEL 1380-100944-12 HUMIDITY SENSOR..SCP
TEL 1380-101130-11 CONNECTOR ASSY VJ10-59-2
TEL 1380-101146-1 FLAT CABLEZ-X
TEL 1380-101173-11 FLAG FOR SENSOR (T170-01330-2)
TEL 1380-101264-11 MOTOR, PINCETTE X AXIA
TEL 1380-101265-11 X HOME SENSOR CS-E-2
TEL 1380-101266-11 X CHECK SENSOR CS-E-25-0
TEL 1380-101267-11 X OUT SENSOR
TEL 1380-101268-11 MAP OUT SENSOR CS-E-27-0
TEL 1380-101269-11 MAP IN SENSOR CE-E-28-0
TEL 1380-101772-11 POD SENSOR ASSY
TEL 1380-101773-11 HOME SENSOR ASSY
TEL 1380-101774-11 UP LIMIT SENSOR ASSY,1380-1017
TEL 1380-101777-11 WAF SENSOR (HORIZON) ASSY
TEL 1380-101784-11 POD LOCK2 SENSOR ASSY
TEL 1380-101788-11 POD UNLOCK2 SENSOR ASSY
TEL 1380-102244-11 DRIVE BELT..IF-Y(HS)-31
TEL 1380-102437-11 FLOAT SW ASSY..SCP-68-1
TEL 1380-102896-11 FAN UNIT
TEL 1380-103172-11 PCB, X, THETA-BASE
TEL 1380-103190-11 DRIVER SERVO
TEL 1380-103256-11 MOTOR, I/F Y AXIS
TEL 1381-644957-16 TVB3101-1 ISC BOARD ASSY
TEL 1381-645294-12 IMC CONN BOARD
TEL 1381-645459-11 3P M/A DRIVER I/F
TEL 1381-645460-12 OPS PANE CONNECTI
TEL 1381-645731-15 I/F CONN BOARD #2
TEL 1381-647411-11 IO DISPLAY BOARD
TEL 1381-647847-15 PCB ASSY
TEL 1381-647967-11 V7.C/S ARM X BOARD ASSY
TEL 1381-647980-12 TVB1202-1/ANET BOARD ASSY
TEL 1381-64968-12 BOARD ASSY
TEL 1381-649902-11 SENSOR BOARD
TEL 1381-650042-11 INDEXER MAPPING BOARD
TEL 1381-650055-11 IMC EXT BOARD
TEL 1381-659042-13 FIRE SIGNAL RELAY BOARD
TEL 1385-391191-13 PINCETTE, M/A
TEL 1385-444840-11 DC MOTOR ( PX243G01-01B )
TEL 1386-100356-11 SOLENOID ROTARY
TEL 1386-443496-12 CABLE, 3P MA8 THETA
TEL 1386-443498-12 M/A THETA MOTOR
TEL 1386-443499-14 MOTOR, M/A Z AXIS
TEL 1386-443501-13 3P MA8 Z MOTOR CABLE
TEL 1386-443503-12 3P MA8 Z BP SENSOR CABLE
TEL 1386-443504-13 X1 SENSOR HARNESS
TEL 1386-443505-13 X2 SENSOR HARNESS
TEL 1386-443507-14 WF SENSOR HARNESS
TEL 1386-443509-13 MOTOR, M/A X AXIS
TEL 1386-443514-11 3P MA8 Z DRIVER SIGNAL CABLE
TEL 1386-443772-11 PIN UP/DOWN SENSOR ASSY
TEL 1386-443921-12 SENSOR CAPACITANCE
TEL 1386-444163-14 W/F EDGE SEN.L SOURCE
TEL 1386-444165-13 WAFER EDGE SENSOR RECIVER
TEL 1386-444165-15 W/F EDGE SENSOR(R
TEL 1386-444208-12 WAFER STAGE SENSOR
TEL 1386-444227-11 CAPACITANCE SENSOR
TEL 1386-444576-12 FAN
TEL 1386-444581-11 RINSE U/D SENSOR
TEL 1386-444607-15 SHUTTER UP/DOWN SENSOR ASSY
TEL 1386-445099-13 CARRIER SENSOR BOARD
TEL 1386-445204-13 FLEX CABLE
TEL 1386-446459-12 SPIN MOTOR CO****OL CABLE (MATSUSHITA)
TEL 1386-447983-11 INDEXER MOTOR ASSY V7
TEL 1386-448371-11 M/A H.S FLEX CABLE
TEL 1386-448386-11 ASSY SPRING
TEL 1386-448392-12 M/A HSY MOTOR ASSY
TEL 1386-448912-11 CABLE, MOTOR, EXT
TEL 1386-450112-13 INDEXER MAPPING SENSOR ASSY
TEL 1386-450142-12 FLAT CABLE
TEL 1386-453040-12 MOTOR SHAFT (MSM021ABF)
TEL 1386-453098-11 POSITION SENSOR
TEL 1386-453643-11 TABOT ARM1 IN/OUT SENSOR HARNESS
TEL 1386-453644-13 TABOT ARM2 UP/DOWN SENSOR HARNESS
TEL 1386-453645-11 TABOT ARM2 IN/OUT SENSOR HARNESS
TEL 1386-458644-11 SMIF ARM X HOME SENSOR ASSY
TEL 1386-459764-11 FLAT 345 CABLE L1950
TEL 1386-459765-11 FLAT 645 CABLE L1950
TEL 1387-432587-11 VALVE SOLENOID
TEL 1393-739729-3 MANOMETER GAUGE
TEL 15030T-11111 PLATE,RF,PC1,REV4
TEL 152-004OK VALVE PNEU NW40
TEL 1520044 SCAN AMP CABLE
TEL 17B4495 FRONT SLIT (R510)
TEL 17B7652 GRAPHITE GROUND ELECTRODE
TEL 180004901 BEARING
TEL 1805-220008-11 WINDOW..VIEW PORT-B(SAME:S3T40
TEL 1805-220014-14 OUTER F/R (8 ORI-FLA)Y
TEL 1805-220135-13 RING, EXT OUTER
TEL 1805-220177-22 RING, SHIELD
TEL 1805-320002-11 HOLDER QUARTZ IEM
TEL 1805-320127-21 BASE RING, INTEGRATED
TEL 1805-320142-11 RING, BASE EXH F/R HOLD
TEL 1805-420008-11 WINDOW, EPD/IE-OX
TEL 181-000450-16 PCB, MC-31039B HSDL GAS VER. 1B
TEL 1810-120415-13 UPPER ELECTRODE BODY
TEL 1810-120531-13 ELECTRODE, UPPER
TEL 1810-120660-13 UPPER ELECTRODE BODY, UNITY 85PE, CP20
TEL 1810-120721-A TEL BOTTOM ELECTRODE
TEL 1810-120721-A4 BOTTOM ELECTRODE
TEL 1810-120900-A8 CHUCK
TEL 1810-120982-11 BOTTOM ELECTRODE
TEL 1810-121051-11 CLAMP RING (OUTER)
TEL 1810-121085-16 ALUMINIUM DEPO SHIELD P/C 1
TEL 1810-121113-13 UEL BODY (UPPER ELECTRODE BODY)
TEL 1810-121244-A1 REPAIR CHARGE
TEL 1810-121299-11 ELECT CHUCK IEM
TEL 1810-121366-11 SHIELD, DEPO
TEL 1810-121429-11 DEPO SHIELD S(C SIC)TYPE2(SAME)
TEL 1810-121900-13 LINER A EXH-Y
TEL 1810-220725-2 EXHAUST RING
TEL 1810-220843-14 VACUUM MANIFOLD(51)
TEL 1810-220986-14 INS GUARD(8K-ESC)
TEL 1810-220998-12 UPPER ELECTRODE PLATE
TEL 1810-221018 RING, P C SHEALD THIN TYPE
TEL 1810-221024-14 UPPER CLEAN PLATE (8K-7A)
TEL 1810-221063-14 RING EXHAUST
TEL 1810-221106-14 CARBON 6"(ESC)
TEL 1810-221329-12 SHIELD RING T78K-160
TEL 1810-221439-25 CRYSTAL ELECTRODE TQM(BK-150)
TEL 1810-221466-12 PLATE COOLING UPPER
TEL 1810-221470-24 ELECTRODE CRYSTAL
TEL 1810-221471-13 ELECTRODE CRYSTAL
TEL 1810-221471-14 ELECTRODE CRYSTAL
TEL 1810-221584-12 PLATE, UPPER COOLING (8K-SI-200)
TEL 1810-221616-12 TRAP (200-S-16)
TEL 1810-221716-11 UPPER ELECTRODE PLATE (FT-3)
TEL 1810-221942-12 AMORPHOUS CARBON
TEL 1810-222433-11 RING, INNER  NW G UP 8
TEL 1810-222435-11 FOCUS RING, QUARTZ, 8K-ESC
TEL 1810-222435-118-220- (8K-ESC) FOCUS RING QUARTZ,1810-222435-118-220-30
TEL 1810-222487-11 SHIELD RING T7(8K-160)
TEL 1810-222662-11/22-EBW-506 SHIELD RING
TEL 1810-222727-11 BAFFLE B
TEL 1810-222728-11 BAFFLE C
TEL 1810-222897-12 NW 31-U (8K-ESC) FOCUS RING (AL)
TEL 1810-222917-11 PROTECT RING2(IEM POLY)
TEL 1810-222956-13 UPPER HOLDER
TEL 1810-222979-12 SHIELD RING
TEL 1810-223063-11 HOLDER UPPER E (TYPE2)
TEL 1810-223101-11 SHIELD BOTTOM A (IEM POLY)
TEL 1810-223147-12 OUTER QTZ WINDOW
TEL 1810-223288-13 MTG FLANGE EXT PLATE (GROUND)
TEL 1810-223497-13 SHIELD BOTTOM B2 (IEM POLY)
TEL 1810-224159-12 BASE A, WINDOW (EPD)(95DI)
TEL 1810-224222-12 UPPER COOLING PLATE
TEL 1810-224506-11 FOCUS RING 6"L AR(8K-ESC)
TEL 1810-224530-11 INNER RING 6J-G-UP-9K-ESC
TEL 1810-224953-12 LINER C GATE CHAM-Y
TEL 1810-224954-11 PLATE COOLING UPPER(T10-215)F
TEL 1810-225157-12 SHIELD RING T5 (8K-160)FP
TEL 1810-322023-11 BELLOWS GUARD RIN
TEL 1810-322044-1 CENTERING W/MESH
TEL 1810-322044-11 CENTERING
TEL 1810-322129-12 EXH RING A (8K-ESC)
TEL 1810-322488-11 GUARD RING (5K1)
TEL 1810-322531-12 RING,GUARD [8K-ESC]
TEL 1810-322767-11 FRANGE, PUSHER
TEL 1810-323129-11 PROTECT RING
TEL 1810-323168-11 SIDE WINDOW PLATE (U85P)
TEL 1810-323593-11 WINDOW (IPP)
TEL 1810-323880-13 FOCUS RING(SAME:S3T40396)
TEL 1810-323881-13 FOCUS INNER RING
TEL 1810-323881-14 RING FOCUS INNER 8" NOTCH C
TEL 1810-324461-11 GUARD RING (8K-397.5)
TEL 1810-324676-11 OUTER QUARTZ END WINDOW
TEL 1810-325487-13 F.R COVER (8N-26-C)
TEL 1810-325508-11 ORIFACE WINDOW (IPP)
TEL 1810-325509-13 COVER, SCREW,CELAZOLE
TEL 1810-325569-13 WALL ALUMINIUM CHAMBER (UPPER) (GROUND)
TEL 1810-325570-13 WALLALUMINIUM CHAMBER (LOWER) (GROUND)
TEL 1810-325571-14 CHAMBER ALUMINIUM WALL (R) (GROUND)
TEL 1810-325572-14 CHAMBER ALUMINUM WALL (GROUND)
TEL 1810-326904-12 FOCUS RING ATACHED (8N220 SI-AL (8K-ESC)
TEL 1810-328378-11 PIPE CONNECT, HE, SP (UP)
TEL 1810-329022-13 LONER ADAPTER(AL)TYPE2(SCCM-0X)
TEL 1810-329037-13 LINER B EXH-Y
TEL 1810-329064-12 WINDOW, AL-3-Y
TEL 1810-329078-11 COVER SCREW A-AL-Y
TEL 1810-329079-11 COVER SCREW B-AL-Y
TEL 1810-329229-11 INNER F/R8"NC216 (RS-T4.45)
TEL 1810-424668-11 UPPER ARM WIRE
TEL 1810-424709-11 WIRE 190
TEL 1810-424742-11 SPACER
TEL 1810-424751-11 ATC FLEX PIPINGN
TEL 1810-424884-14 RING,GUARD INSULATOR
TEL 1810-424952-13 LIFTER SPRING (8K-ESC)
TEL 1810-424955-11 ROD, RF 8K-ESC
TEL 1810-425088-11 LIFTER STOPPER A (8K)
TEL 1810-425099-12 WAFER LIFTER
TEL 1810-425153-11 MTG PIN (8K-ESC)
TEL 1810-425512-12 CENTERING PIN 2
TEL 1810-425600-11 STOPPER (DEPO SHIELD)
TEL 1810-425601-11 STOPPER SCREW (DEPOSHIELD)
TEL 1810-425704-12 CLOAK LAMP A
TEL 1810-425705-12 CLOAK LAMP B
TEL 1810-425994-11 TEMP SENSOR HOLDER(KI)
TEL 1810-426117-11 SHAFT, CLAMP SUPPORT D
TEL 1810-426423-11 ATC TRAP PLATE SCREW
TEL 1810-426760-11 WINDOW, SIDE
TEL 1810-427135-11 PIN (4X15)  IS AN ALTERNATIVE)
TEL 1810-427899-12 DEPO SHIELD H=70 ALUMINA
TEL 1810-428078-12 STOPPER LIFTER
TEL 1810-428129-11 WIND SHIELD
TEL 1810-428390-11 BAFFLE A
TEL 1810-428436-11 END POINT WINDOW TEFLON SCREW
TEL 1810-428520-12 BOTTOM EL PIN (0.5)
TEL 1810-428720-12 PIN POSITIONING (IEM POLY)
TEL 1810-429708-11 WIRE (260)K8
TEL 1810-429709-11 WIRE (276)K8
TEL 1810-429712-11  (PIN (4X17) IS AN ALTERNATIVE)
TEL 1810-429803-11 GATE RETURN SPRING P
TEL 1810-429841-11 BUSH RING SHIELD
TEL 1810-429842-11 SCREW SET SHIELD (OLD P/N 1810-428864-11)
TEL 1810-430545-12 HANDLE, EXH
TEL 1810-430589-11 PLATE WINDOW
TEL 1810-430590-11 MESH WINDOW(EPD)(95DI)
TEL 1810-430592-11 WINDOW, UV CUT FILM
TEL 1810-430766-11 CAP SCREW (M6-ESC) (TYPE2)
TEL 1810-430782-11 CLT GAS INLET JOINT TOP B(STD)
TEL 1810-430809-11 SPRING, LIFTER C
TEL 1810-431219-11 PIN LOCATE CENTERING(EPD)
TEL 1810322489-12 CERAMIC FOCUS RING
TEL 1820-00024R PCB SYS 386/33MHZ
TEL 1880-020094-16 MATCHER MFM-20SA2 (189502009413
TEL 1880-026696-12 AMORPHOUS CARBON
TEL 1880-026779-12 AMORPHOUS CARBON
TEL 1880-026855-11 MECHANICAL SEAL
TEL 1880-027021-12 BELLOWS SN4730000-3
TEL 1880-028435-12 RF MATCHING UNIT
TEL 1880-26785-21 AMORPHOUS CARBON
TEL 1881-022021-13 AGV5W I/F BOARD
TEL 1881-022036-32 PCB OPE-PANE SW BOARD (DTM)
TEL 1881-022117-26 PCB TSBC-V30B(MAIN)K8 (ATM/MAIN 08)
TEL 1881-022117-27 PCB TSBC-V30B(MAIN)K8 (ATM/MAIN 08)
TEL 1881-022139-12 PCB H/A INTCON BOARD 2 (ATM)
TEL 1881-022143-12 PCB P/A CO****OL BOARD 2(ATM)
TEL 1885-020003-12 B. E. (6") ASSY
TEL 1885-020964-14 RING, P C SHEALD THIN TYPE
TEL 1885-022352-14 BOTTOM ELECTRODE
TEL 1885-023137-17 ELECTRODE BOTTOM
TEL 1885-023937-11 ELECTRODE ASSY..BOTTOM (6"-5KB)
TEL 1885-024611-12 PLATE, INPUT RF
TEL 1885-024612-12 PLATE, GROUND
TEL 1885-024718-11 C P/C RING (85-T7-220-CZ)
TEL 1885-026690-11 HOLDER, WAFER
TEL 1886-455194-11 H/AX MOTOR ASSY
TEL 1886-455293-11 SENSOR MOTOR ASSY
TEL 1886-459396-12 SENSOR ASSY PTL/L1
TEL 1887-422021-11 P/C WINDOW HETERASS'Y
TEL 1902-411203-12 MOTOR PULLEY
TEL 1902-411263-11 MOTOR PULLEY(S3M20F)
TEL 1904-300052-13 SIDE PLATE (R)
TEL 1904-300053-13 SIDE PLATE (L)
TEL 1904-400031-11 SPACER GUIDE 7.8
TEL 1910-110960-11 BASE UNIT
TEL 1910-315920-12 DAMPER
TEL 1910-317263-12 GUIDE PIQ
TEL 1910-317659-17 NOZZLE BATH, 8 INCH
TEL 1910-318300-11 WAFER GUIDE (6")
TEL 1910-318771-13 GAP SPACER(8")
TEL 1910-319994-11 AL COVER U
TEL 1910-319995-11 AL COVER T
TEL 1910-321310-13 GUIDE (L)
TEL 1910-321311-13 GUIDE (R)
TEL 1910-418164-13 DAMPER SHUFT
TEL 1910-418203-12 NOZZLE BRACKET 2
TEL 1910-418217-12 PACHING
TEL 1910-422378-11 WAF GUIDE (6")
TEL 1910-424625-12 PULLEY SHAFT
TEL 1910-425777-1 PIN
TEL 1910-428916-11 CHIP GUIDE
TEL 1910-429087-12 NOZZLE HOLDER
TEL 1910-429745-12 NOZZLE, HOLDER
TEL 1910-430884-12 TUBE CONNECTER
TEL 1910-433828-11 PIN
TEL 1910-435937-11 BLOCK IDLE
TEL 1910-442219-11 VAC SEAL TOOL
TEL 1910-449604-11 BLIND
TEL 1910-457427-11 BUFFER
TEL 1910-457558-11 WAFER GUIDE
TEL 1920-411191-11 PULLY
TEL 1981-603313-11 LED DISPLAY BOARD
TEL 1981-607041-13 STEP5 MOTOR DRIVE BOARD
TEL 1981-607569-11 PCB, USER BOARD ASSY
TEL 1985-41190-13 8" COATER CATCH CUP ASSY
TEL 1985-414025-11 I/F GAP PIN ASSY
TEL 1985-416828-11 CENTERING JIG 6 INCH
TEL 1985-425503-12 PIN (AD) 7" (PACK OF 6)
TEL 1985-425512-13 8" PIN SET ASSY
TEL 1986-401324-11 8 COL PIN UP SENSOR ASSY L200
TEL 1986-401325-11 8 COL PIN DOWN SENSOR ASSY L200
TEL 1986-416108-11 AC CABLE OLF 2.5SQ:3C SS
TEL 1986-421055-1 M/A WAFER SENSOR ASS
TEL 1987-410294-11 M/A S.S Z COIL SPRING
TEL 1987-411444-11 ASSY, 3P M/A S.S Z
TEL 1987-411593-12 SERVO DRIVER
TEL 1987-423370-1 SWITCH EMO BOX
TEL 1B05-100148-14 COOLING HOSE(8)
TEL 1B05-100149-13 HOT DIW TANK
TEL 1B05-100214-12 GUIDE,WAF200Z MS 8 CHUCK
TEL 1B05-100260-11 8BOAT (QZ)
TEL 1B05-100271-11 6" CHUCK(QZ)-52
TEL 1B05-100288-11 6" BOAT(QZ)-52-H.
TEL 1B05-100327-11 8BATH QDR TYPE-E(NS)
TEL 1B05-100354-12 8 BATH FR TYPE-E (MG)
TEL 1B05-200040-13 FLUME(8 INCH-N)
TEL 1B05-200045-14 DRAIN RECEIVING TRAY(GS)
TEL 1B05-200052-12 8 BAFFLE QZ(TYPE-C)
TEL 1B05-200084-11 8BAFFLE QZ(TYPE-B-S)-2
TEL 1B05-200090-11 6" BAFFLE SPM
TEL 1B05-200095-11 6" BAFFLE QZ
TEL 1B05-300046-12 SUB FLUME (8-A)
TEL 1B05-300047-12 SUB FLUME (8-B)
TEL 1B05-300048-12 SUB FLUME (8-C)
TEL 1B05-300049-12 SUB FLUME (8-D)
TEL 1B05-300071-11 PUNCHING PLATE(AP
TEL 1B05-400065-11 SENSOR GLASS
TEL 1B05-400078-11 QUARTZ PIPE(150)
TEL 1B81-001551-11 LS CN BOARD
TEL 1B81-010067-16 N2 SENSOR BOARD
TEL 1B81-010123-16 PCB BOARD
TEL 1B81-010267-13 P064 BOARD CIRCUIT
TEL 1B81-010273-14 C2H INTLK BOARD
TEL 1B86-030137-12 W/TRA DRV ZE CABLE 4
TEL 1B86-032474-13 INDEXER POSI SENS ASSY
TEL 1B86-032475-13 INDEXER SENS ASSY
TEL 1B86-032669-14 INDEXER CAR SENS(T) ASSY
TEL 1B86-032670-14 INDEXER CAR SENSASSY
TEL 1B86-032673-12 INDEXER POD LK SENS ASS
TEL 1B86-032674-12 INDEXER POD ULK SENS ASSY
TEL 1B86-032677-14 INDEXER CONN BRD CABLE
TEL 1B86-034056-17 INDEXER POD LK SENS ASSY-R
TEL 1B86-034057-17 INDEXER POD ULK SENS ASSY-R
TEL 1B86-035917-12 INDEXER POD CHECK RBT-CABLE
TEL 1B86-035918-12 INDEXER LATCH RBT-CABLE
TEL 1B87-512644-11 ASSY, SMIF TABLE
TEL 1D05-300040-13 RING,INSULATOR, C, (DRM2) QUARTZ
TEL 1D05-300052-11 RING INSULATOR A7
TEL 1D05-300053-14 RING.INSULATER B2(DRM2)
TEL 1D05-300185-13 RING INSULATER A7(HF1 0)(DRM2)
TEL 1D05-400022C14 WINDOW SHIELD DEPO (DRM2)
TEL 1D08-000321-11 BOARD TYB422-1
TEL 1D10-100075-14 BAFFLE PLATE LEVEL 5 (PC-3)
TEL 1D10-100327-13 PLATE
TEL 1D10-100582-14 ELECTRODE BOTTOM
TEL 1D10-100938-12 RF PLATE,PC1 (DRM2)
TEL 1D10-101111-11 PLATE, RF, P2C, (DRM2)
TEL 1D10-101965-12 ELECTRODE BOTTOM, 8N-L2 (88DRM
TEL 1D10-102521-12 SHIELD DEPO UPPER-Y
TEL 1D10-200704-14 UPPER EL-BASE 1
TEL 1D10-200733-11 SHIELD RING (DRM2)
TEL 1D10-200734-14 COVER BELLOWS A
TEL 1D10-200921-12 DEPO, SEALD P1
TEL 1D10-200922-12 SHIELD, DEPO, P2
TEL 1D10-201429-15 UPPER,ELECTRODE R1
TEL 1D10-202177-12 UPPER ELECTRODE A-1 (DRM2)
TEL 1D10-301273-12 SHUTTER (LV-5)
TEL 1D10-302209-14 FOCUS RING
TEL 1D10-302791-12 RING, F-8J-SIC-260-3.4 (DRM2)
TEL 1D10-302869-11 PIN, BUSHER
TEL 1D10-303124-14 SHIELD DEPO 85-2(DRM2)
TEL 1D10-303124-16 SHIELD,DEPO 85-2
TEL 1D10-304010-11 RING,SHIELD B3
TEL 1D10-304010-12 RING..SHIELD,B3,(DRM2)
TEL 1D10-311758-11 RING, BELLOWS LOWER
TEL 1D10-312637-11 COVER BEL-L2 (C-ESC) (DRM2)
TEL 1D10-328005-11 COVER, PROTECT, ESC
TEL 1D10-401049-1 SCREW CAP PTFE (UNITY)
TEL 1D10-401722-11 COVER,BEL(DRM)
TEL 1D10-401952-11 PLATE STOPER PIN
TEL 1D10-403321-11 WINDOW SPACER M8
TEL 1D10-404153-11 EDGE PRESSURE CERAMIC SLEEVE
TEL 1D1O-312197-11 RING F-8SO-SIC (A B)
TEL 1D80-000759-11 BURRERFLY VALVE
TEL 1D80-002363-12 GATE VALVE
TEL 1D80-002513-14 REMOTE CO****OL BOX
TEL 1D80-003507-21 AUTOMATIC MATCHING NETWORKMW2-30
TEL 1D80-003885-11 PCV..UPC-4JR-L124-C13S
TEL 1D80-004122-17 WMN-30F BOTTOM MATCHER OF  85 SCCM 2Mhz.
TEL 1D81-000120-1 PCB ASSY
TEL 1D81-000141-21 TYB41E-2 TMP BOARD
TEL 1D81-000303-18 PCB, TYP131-1/ILK
TEL 1D81-000304-31 BOARD  I/F PRESSURE SWITCH
TEL 1D86-000172-91 RF CABLE (P/C3)
TEL 1D86-003596-12 HEAT:PC:PC1 WALL RR ASSY
TEL 1D86-003620-13 TC
TEL 1D86-003781-13 ASSY, BTM
TEL 1D86-003946-14 CA: MAIN: PC1DCPWR (CABLE)
TEL 1D86-004229-13 CABLE,PC,PC2,BTM.PANEL
TEL 1D86-004358-13 TC, UNITY2
TEL 1D86-006871-41 CA:OUT:PC1:XINIX SCAN
TEL 1D86-006873-41 CA:OUT:PC1:XINIX DET1
TEL 1D87-000340-11 STD P/C2 CYLINDER
TEL 1IH0012710 MICRO PHOTO SENSOR
TEL 1JK0013000 OPTICAL FIBER CABLE
TEL 1M10-101054-12 6" ANODE
TEL 1M10-202045-13 ELECTRODE UPPER
TEL 1M10-303699-11 LIFTER PIN, TEFLON COATED
TEL 1M81-022067-11 CPU BORAD
TEL 1M87-000305-11 RECIPE MODULE VER.2
TEL 1N10-400438-1 SCREW CAP (M4)
TEL 1N10-401061-11 HOLDER CAP SCREW
TEL 1N10-401561-12 VACUUM SCREW M6X25(AL)
TEL 1N10-401834-11 GAS INLET
TEL 1N10-402078-11 VACUUM SCREW M6X16
TEL 1N10-402079-11 AL SCREW M4X8
TEL 1N10-402337-11 LOCATING PIN
TEL 1N10-402384-11 SCREW CAP M5 (2) (PTFE)
TEL 1N10-402385-11 SCREW CAP M6 (2) (PTFE)
TEL 1N10-402473-11 DEPO SHIELD (ES)
TEL 1N10-403168-12 PORT SLEEVE (2-7)
TEL 1N86-431263-11 MOTOR ASSY,SDR STG-X(SD14)
TEL 1PS0005000 POWER SUPPLY EPD-
TEL 1PS0016500 POWER SUPPLY (ET-5B)
TEL 1PS0019890 MFC POWER SUPPLY
TEL 1PS0031810 POWER SUPPLY(SD-21A),FOR(BE-727)
TEL 1SU0004000 LMT SWITCH
TEL 1V10-361804-11 CERAMIC BLOCK
TEL 1V10-361804-12 NTF FARADAY INSULATOR
TEL 1V10-463635-1 XP LINER CAP SCREW(M4*65.8)
TEL 1V86-346055-11 CA. ASSY WIDE BIAS F/THRU
TEL 2-140V747-75 O-RING,027-100165-1
TEL 2-AJ-80179-1 SPIN CUP (LOWERASSY,200mm)
TEL 2-FI-30946 SPIN CUP LOWER
TEL 20-000012 SCREW CAP M3X12 SUS304
TEL 20-0550 THERMOCOUPLE GAUGE TUBE
TEL 20-0550 ANE TC GAUGE TUBE 20-0550 ANE
TEL 20033101 UNITY LOADLOCK DOOR
TEL 200998 CHAIN DRIVE BELT
TEL 201HS-D2 HIGH PRESSURE LAMP
TEL 2024-003015-1 SPEED CO****OLLER, AS2201F-01-04
TEL 2040-000228-1 MOTOR DRIVER, AK-BK551C
TEL 204090 QUARTZ MOUNTING PLATE
TEL 2102-420430-11 BEARING
TEL 2105-120178-11 TUBE, PROCESS, A858
TEL 2105-120548-51 QUARTZ, FIN PEDESTAL
TEL 2105-220154-11 BASE,PEDESTAL GATE
TEL 2105-220155-11 COVER,PEDESTAL GATE
TEL 2105-220834-11 QUARTZ RING
TEL 2105-320040-13 COVER,PEDESTAL GATE
TEL 2105-320185-11 QUARTZ, BASE 12
TEL 2105-420062-11 GATE,QUARTZ,POSITIONING
TEL 2105-420384-31 QUARTZ INJECTOR
TEL 2105-420416-51 QUARTZ INJECTOR
TEL 211-462431-11 CABLE CLAMP
TEL 2110-223783-11 HEAT INSULATOR (1)
TEL 2110-223784-11 HEAT INSULATOR (2)
TEL 2110-324792-12 FLEX, TUBE (N2)
TEL 2110-325280-12 ASSY, TUBE, FLEX. 1/4"
TEL 2110-330148-11 SPACER,TEFLON
TEL 2110-332335-11 FLANGE, WATER COOLING (UNDER)
TEL 2110-338369-11 STRAIGHT PIPE FROM ELBOW TEL FURN
TEL 2110-339633-11 PANEL HEATER
TEL 2110-339634-11 PANEL HEATER
TEL 2110-348521-12 PANEL HEATER.FZ-41 1/4"V WITH FUSE
TEL 2110-348937-12 PANEL HEATER.FZ-41 1/4"V WITH FUSE
TEL 2110-421831-12 LABYRINTH SEAL,INNER
TEL 2110-430534-11 COLOR (1)..PTFE
TEL 2110-430535-11 COLOR (2)..PTFE
TEL 2110-430536-11 COLOR (3)..PTFE
TEL 2110-462324-11 TAPE HEATER
TEL 2181-020009-13 PCB ASSY STC-C
TEL 2181-020010-13 PCB ASSY STC-P
TEL 2181-020014-13 PCB ASSY F/C-DSP
TEL 2181-020016-11 PCB ASSY SNS B
TEL 2181-020017-11 PCB ASSY
TEL 2181-020023-13 PCB ASSY ALM-ST1
TEL 2181-020025-11 PCB ASSY SNS I/L
TEL 2181-020026-13 PCB ASSY MT-I/L
TEL 2181-020033-11 PCB ASSY MECH-I/L
TEL 2181-020036-11 PCB ASSY OPDD;IW
TEL 2181-020039-11 PCB ASSY SNS B-2
TEL 2181-020041-1B PCB ASSY, MC-31050P-I
TEL 2181-020056-1C PCB, GAS, FIRMWARE, I/L
TEL 2181-020057-13 PCB, PWR SUPPL CONT GAS DETECTOR
TEL 2185-024028-15 ASSY,FLEX,1/4 MARKING S (PACK OF 2)
TEL 2185-027393-11 ASSY,MANIFOLD UNIT,R
TEL 2185-027981-11 MANIFOLD UNIT SIN
TEL 2185-033510-16 ASSY, INNER TUBE TRAP
TEL 2185-033652-11 COLD TRAP BODY RWK
TEL 2187-108750-11 MANIFOLD, 8S-R-AO-W-I-1
TEL 2187-108751-11 MANIFOLD, 8SN-R-A6-W-I-1
TEL 2187-108961-11 MANIFOLD
TEL 2187-150087-11 CERAMIC CLAMP
TEL 22110-324790-12 ASSY, TUBE, FLEX. 1/4"
TEL 23-020624 REV3 FIRE DETECT MAIN CPU BOARD
TEL 23-020627 R**** LED DISPLAY BOARD FIRE DETECTION
TEL 23-030632 REV1 FIRE DETECTION CONNECTION BOARD
TEL 23114-001-5011 TRANSFORMER 118V50/60
TEL 234117 ORING SILICON VACUUM CHUCK
TEL 234118 ORING SILICON VACUUM CHUCK
TEL 234124 ORING SILICON VACUUM CHUCK
TEL 240-000648-1 FLOW METER P-500-1LPA-H2O-15L
TEL 240035781 FILTER CEP-TM1S-VR
TEL 24821 PCB GRAPHIC LCD DRIVER
TEL 249-9200 POTENTIOMETER
TEL 25007-106 PCB LASER DRIVER
TEL 26054K4079 O-RING,KALREZ,027-001397-1
TEL 265-336 LT1085CT OBJECTIVE LENS VOLTAGE REGULATOR
TEL 270013901 GASKET
TEL 2805-106655 FILTER ASSY
TEL 281-600223-3 A-L Z LIMIT SWITCH
TEL 281-600601-1 HEX LIMIT SENSOR
TEL 283191 LIP SEAL FOR NEW STYLE END EFFECTOR
TEL 2835-5297 QUARTZ FIBRE 3X72.8M
TEL 28483232 IRRADIANCE AMPLIFIER FILTERS
TEL 286-000964-1 UP ARM MOTOR
TEL 286-000965-1 DOWN ARM MOTOR
TEL 287-000769-1 X MOTOR ASSY
TEL 287-000771-1 X MOTOR ASSY
TEL 287-002337-5 80E HOT CHUCK POWER
TEL 29041B DIFFUSION LINE HEATER
TEL 2910-207103-11 CUP INNER
TEL 2910-22077-12 CHAMBER
TEL 2910-290041-12 8" TWEEZER
TEL 2910-321966-12 STF121 CWD DISK
TEL 2910-324012-11 TUBE
TEL 2910-399191-11 HOLDER(12),FBR
TEL 2910-400200-12 PIN (ACT 8)
TEL 2910-400229-12 PIN
TEL 2910-400884-13 PIN
TEL 2910-400909-1 TUBE SOLVENT (0-3-110) (ACT 8)
TEL 2910-401736-12 PIN
TEL 2910-403787-12 8" ACT PIN (ADH)
TEL 2910-404308-12 POSITION PIN
TEL 2910-415900-11 PIN
TEL 2910-490019-11 POSITIONING PIN
TEL 2910-494964-11 PROBE
TEL 2911-000008-11 FLANGE,
TEL 2940-000022-11 MOTOR DRIVER
TEL 2980-090718-11 SPIN CHUCK
TEL 2980-090819-11 SERVO MOTOR.  (ACT 8)
TEL 2980-091812-11 CHEMICAL CONN BOARD
TEL 2980-106276-11 FLOAT SW ASS  CF-0354
TEL 2980-190355-11 UV SENSER
TEL 2980-190356-11 UV SENSOR US365T
TEL 2980-191730-11 MOTOR DRIVER, MSD261YT
TEL 2980-193265-11 BELT
TEL 2980-193267-11 PULLY ASSY
TEL 2980-193268-11 IDLER,TENSION
TEL 2980-193305-11 BELT
TEL 2980-193308-11 PULLY(HOME)
TEL 2980-193348-11 LINE 8,9,10 CABLE
TEL 2980-193373-11 THEATA MOTOR ASSY
TEL 2980-195729-11 PULLY(END)
TEL 2981-600589-11 CHEMICAL I/O BOARD SP003
TEL 2985-401528-13 Z DRIVE PULLEY ASSY
TEL 2985-402390-14 300CC L/E TANK
TEL 2985-429601-12 IRA FORK ASSY ACT12
TEL 2985-479717-13 PULLEY ASSY(ACT12),X DRIVE
TEL 2985-479717-14 PULLEY ASSY(ACT12), X DRIVE
TEL 2985-479718-14 PULLEY ASSY(ACT12) ,X IDLER
TEL 2985-479721-12 PULLY ASSY(ACT12),Z ID LER
TEL 2985-485085-11 BLOCK ASSY,12INCH
TEL 2985-485128-12 BLOCK ASSY,12INCH
TEL 2986-400319-12 X-MOTOR ASSY (ACT 8)
TEL 2986-400395-12 SCAN ARM MOTOR (ACT 8)
TEL 2986-400506-11 CT CHANGER MOTOR ASSY (ACT 8)
TEL 2986-400570-11 DO EXT CABLE No.6
TEL 2986-4008235-13 12 DEV CHK U/D SENSOR ASSY
TEL 2986-400834-13 12DEV CHK U/D SENSOR CABLE
TEL 2986-401149-13 FAN (109P0424H3D01)
TEL 2986-401217-12 ASSY, 8" BELT SENSOR
TEL 2986-402779-16 CAPACITANCE SENSOR
TEL 2986-408952-W1 CABLE, 1500, M4P-M3J
TEL 2986-409039-11 LEAK SENSOR ASSY
TEL 2986-419488-W1 CABLE, #2, 4000, M3P-M3J
TEL 2986-419545-W1 CABLE, #2, 3000, M3P-M3J
TEL 2986-419594-W1 CABLE, 4000, M4P-M3J
TEL 2986-427126-11 SENSOR PHOTO 8 IRA L #001 330
TEL 2986-427128-11 SENSOR PHOTO 8 IRA D #001 140
TEL 2986-430491-W1 CABLE, #2, 1500, M3P-M3J
TEL 2986-434506-W1 CABLE, #2, 2500, M3P-M3J
TEL 2986-438957-W1 CABLE, #1, 600, M3P-M3P
TEL 2GN60K GEAR HEAD
TEL 2K070-010AN RADIAL BEARING MGC42100-7
TEL 2T3-4040-000 ALUMINIUM WAVERING (ORDERED IN 5/SET)
TEL 3-827667-14 O-RING
TEL 3-827667-16 O-RING
TEL 3-827667-18 O-RING
TEL 3-827674-17 O-RING
TEL 3-831868-01 QUARTZ PLATE
TEL 3-832776-03 O-RING
TEL 3-837424-05 O-RING
TEL 3-837424-07 O-RING
TEL 301-336.801-014 RUBBER JOYSTICK NEW
TEL 301-364.200-000 WAFER SENSOR TRANSMITTER
TEL 301-364.202-000 WAFER SENSOR RECEIVER
TEL 301-364.203-000 WAFER SENSOR AMPLIFIER
TEL 302-013090-024 CONNECTOR
TEL 302-077.001-003 EMITTER
TEL 302-490108-1 PULLEY (SMALL)
TEL 307-144.001-008 LAMP ASSY
TEL 3083160 RELAY,TEMP,CO****OL
TEL 310-111271-03 BASE, DEV
TEL 310-111550-04 COATER BASE
TEL 310-216120-1 SHUTTER BASE
TEL 310-290498-1 SPIN CHUCK 6''
TEL 310-290647-7 PINCETTE CERAMIC ARM
TEL 310-290659-4 I/F PINCETTE
TEL 310-312106-3 KNIFE EDGE RING
TEL 310-313986-1 UPPER CUP (A)
TEL 310-316008-2 UPPER RING
TEL 310-332086-01 NOZZLE PLATE
TEL 310-332521-1 UPPER CUP
TEL 310-344509-1 UPPER RING (POSI)
TEL 310-346181-2 THERMO CONNECTOR NOZZLE
TEL 310-390483-4 PANEL COVER
TEL 310-390507-1 T.S.R NOZZLE
TEL 310-390767-3 8" EDGE RING
TEL 310-390767-4 KNIFE EDGE RING
TEL 310-390769-3 8" NOZZLE RING
TEL 310-391866-2 ARM SIDE RINSE
TEL 310-400116-2 MORTOR PULLY
TEL 310-405623-3 VANE LIMIT (A)
TEL 310-411131-1 SLIDE SENSOR
TEL 310-411182-1 PULLEY
TEL 310-411183-2 SHAFT(2)PULLEY MK2
TEL 310-411508-1 BRACKET MOTOR COOLING UNIT MK2
TEL 310-411843-1 INNER RING
TEL 310-412110-1 PULLEY SHAFT
TEL 310-412226-1 SHAFT(1)PULLEY MK2
TEL 310-415664-1 PULLEY
TEL 310-426697-2 6" INNER CUP STANDARD
TEL 310-428311-1 WAFER GUIDE
TEL 310-428537-3 ROLLER TRM COT09X
TEL 310-449080-3 TIMING PULLEY
TEL 310-461746-3 NOZZLE,ARM
TEL 310-474688-2 FITTING BLOCK
TEL 310-475341-2 FITTING HANDLE
TEL 310-490073-1 NUT PLATE
TEL 310-490090-2 PULLEY COLOR
TEL 310-491063-1 PACKING
TEL 310-492369-1 VAC SEAL CASE
TEL 310-492370-1 VAC SEAL PRESSURE
TEL 310-492473-1 HEAD COVER HINGE (TOKYO ELECT)
TEL 310-492474-1 HINGE PLATE (TOKYO ELECT)
TEL 310-492476-1 STAY PIN (TOKYO ELECT)
TEL 310-492970-1 8" LOWER CUP PARKING
TEL 310-493565-1 PACKING
TEL 310-493566-1 PACKING
TEL 310-493599-4 BOLT, STOPPER
TEL 310-494362-1 M/A TEFLON FINGER
TEL 310-495001-1 ROD COLOR
TEL 310-495292-1 ADJUSTING SCREW
TEL 310-495511-2 PINCETTE SUPPORT VU-106 NCR-68-2
TEL 310-495768-2 BRACKET FIBER
TEL 310-495865-1 NOZZLE BEAM
TEL 310-496056-2 SENSOR, BRACKET C
TEL 310-496436-2 SHAFT (A
TEL 310473587-3 WAFER GUIDE
TEL 321-8-X-1DFR FLEX WELDMENT BARATR
TEL 3281-000020-13 FFC PINCETTE 1-2FLAT CABLE
TEL 3320900 ASSY, CABLE
TEL 341C0001-01 NOZZLE FLUID FC-20 FAN SPRAY
TEL 341C0005-03 NOZZLE N2 360/70/80
TEL 3540K012C-145 MOTOR WITH GEARBOX
TEL 3540K012C-177 DRIVE MOTOR LIFT 020-610.807-008PLR
TEL 380-000139-1 CIRCULAR HOT PLATE (MK-II) HP-F-SPB-N
TEL 380-090044-1 SERVO DRAWER
TEL 380-090070-1 SUPER FITTING INSTER 1/4  (380-090070-1)
TEL 380-090079-1 SLEEVE INSERT JIG ST-D
TEL 380-100028-2 SHUTTER ROTARY SOLENOID UNIT
TEL 380-100124-1 SWITCH FLOAT
TEL 380-100126-1 SWITCH FLOAT
TEL 3802-420027-11 BEARING
TEL 3802-420073-11 BEARING
TEL 3802-420075-11 BEARING
TEL 3802-420078-11 BEARING
TEL 3802-420079-11 BEARING
TEL 3802-420080-11 BEARING
TEL 3802-420083-11 BEARING
TEL 3802-420088-11 BEARING
TEL 381-400198-1 SCRUBBER CONNECTOR B.
TEL 381-500066-3 BULK HEAD MOTHER BD
TEL 381-500066-6 IND BULK HEAD MOTHER BD
TEL 381-500221-1 6" OVEN PREAMP BOARD
TEL 381-500221-2 BOARD, 6" OVEN PREAMP
TEL 381-500244-3 16K MEMORY BOARD
TEL 381-534239-1 PCB
TEL 381-534240-1 CPU 1 BOARD
TEL 381-539103-4 M/C KEY I/F BRD A
TEL 381-600039-5 PCA LIMIT SENSOR
TEL 381-600090-1 6" LIMIT SENSOR P.C.A
TEL 381-600090-3 LIMIT SENSOR
TEL 381-600196-9 SCR I\0 BOARD
TEL 381-600209-C ALARM ANALYZER I/0 BOARD
TEL 381-600218-C ALARM ANALYZER CPU BOARD
TEL 381-600222-2 OVEN CONNECTION PCB
TEL 381-600222-9 OVEN CONNECTION BOARD
TEL 381-600223-9 OVEN CPU BOARD
TEL 381-600230-8 SPINNER MOTHER BOARD
TEL 381-600245-2 PCB ASSY
TEL 381-600290-7 HP AD CONNECTION BOARD
TEL 381-600318-4 M/C DI24 BOARD
TEL 381-600337-5 INDEXER CPU BOARD
TEL 381-600338-3 INDEXER I\0 - BOARD
TEL 381-600720-2 PCB
TEL 381-639006-4 PCB, SMC-C85A
TEL 381-639007-5 BOARD IND CONNECTION
TEL 381-639008-3 B/D C/S CONNECT B
TEL 381-639052-4 M.A CONN BRD C ASSY
TEL 381-639067-2 WAFER TRACK (MARK V)
TEL 381-639094-8 PCB, VME-UIO
TEL 381-639101-4 BOARD VIO CONN BR
TEL 381-639101-5 UIO CONNECTION BOARD ASSY
TEL 381-639102-2 BOARD TEMP CONNCT
TEL 381-639102-3 TEMP CONN CRD
TEL 381-639102-9 M/C CONNECTION BRD ASSY
TEL 381-639176 OVER HEAR ALM BOARD
TEL 381-639176-7 BOARD OVER HEAT A
TEL 381-639227-3 SCAN ARM SENSOR BRD
TEL 381-639332-6 MAP TERMINAL BRD ASSY
TEL 381-639378-3 STAGE TERMINAL BOARD ASSY (COATER MARK V)
TEL 381-639383-2 SSMC-8A
TEL 381-639469-2 PCB MARKS DUMMY
TEL 381-639507-3 WAFER TRACK (MARK V)
TEL 381-639513-1 68KSV CONNECTOR,B
TEL 381-639514-2 SSMC-8B
TEL 381-640804-9 BOARD LED DISPLAY BRD
TEL 381-640841-4 TVME-68KSF ASSY
TEL 381-640994-3 UNIT I/O BRD 2
TEL 381-641080-7 UIO/A BOARD
TEL 381-641135-2 UIO/A CON BRD
TEL 381-641739-9 EEW UNIT BOARD
TEL 381-642277-3 TEMP CONN BRD ASS
TEL 381-642664-1 UIO/BS CONN. BOARD
TEL 381-643238-6 BOARD CONNECTION M/A
TEL 3810-329659-21 BRACKET
TEL 3810-420337-11 RETAINER,REACTOR,SUS316L
TEL 3810-422311-11 SCREW SET M6*20
TEL 3810-423848-11 MOUNT MOTOR
TEL 3810-424115-12 SCREW
TEL 3810-424200-11 SCREW M5*6 PEEK
TEL 385-302472-2 CABLE, ASSY, 6"
TEL 385-303511-5 LIQUID END DETECTOR
TEL 385-332398-4 CLAMP
TEL 385-332650-4 DIP DEP POSI DEV BACK RINSE
TEL 385-335707-4 DIP DEV VAC PIPING
TEL 385-390555-3 6" PINCETTE P ASSY
TEL 385-390646-8 MIST TRAP ASSY
TEL 386-400535-2 STEPPING MOTOR ASSY
TEL 386-400536-2 STEPPING MOTOR CABLE
TEL 386-400538-2 INDEXER UNIT CO****.
TEL 386-400553-1 FLAT CABLE ASSY
TEL 386-400554-1 FLAT CABLE ASSY
TEL 386-400597-1 SENSOR ASSY
TEL 386-400598-3 HEAD DOWN & ENG
TEL 386-400600-1 VAC SENSOR HARNESS
TEL 386-400604-1 6" AD CUP DOWN SENSOR
TEL 386-400633-1 SCRUBBER TRM OUT SENSOR
TEL 386-400634-1 SCRUBBERVAC SENSOR
TEL 386-400641-1 SCRUBBER TRM IN SENS.
TEL 386-400644-1 WAFER SENSOR HARNESS
TEL 386-401515-1 IN BELT MOTOR MAR
TEL 386-401516-1 OUT BELT MOTOR MARNE
TEL 386-401753-1 TRM UP/DOWN SENSOR HARNESS
TEL 386-401797-1 COOLING U/D SENSOR
TEL 386-402174-2 M/C UNIT (1) CABLE
TEL 386-402175-2 M/C UNIT (2) CABLE
TEL 386-431106-2 I/O BOARD
TEL 386-433121-2 L/R SCAN 1 UP/DOW
TEL 386-439020-2 CARRIER **** ARM MOTOR A
TEL 386-439025-2 MOTOR
TEL 386-439030-3 ARM Y MOTOR ASSY
TEL 386-439031-3 ARM VAC SENSOR ASSY C/S
TEL 386-439032-3 SENSOR
TEL 386-439073-3 MAIN ARM Y.B.P. SENSOR ASSY
TEL 386-439074-3 MAIN ARM Y ENCODER ASSY
TEL 386-439085-2 MOTOR
TEL 386-439097-2 AL STAGE WAF SENSOR
TEL 386-439152-2 MOTOR
TEL 386-439153-2 MOTOR
TEL 386-439154-2 SENSOR
TEL 386-439154-3 SPIN MTR SCAN ARM
TEL 386-439155-5 NOZZLE HEAD SENSO
TEL 386-439159-3 ROTARY ACTUATOR
TEL 386-439225-3 ARM, PAUSE, SW, ASSY
TEL 386-439377-4 M/A FLEX CABLE
TEL 386-439489-2 SIDE RINSE
TEL 386-439511-4 SVM DRIVE CABLE (7CM)
TEL 386-439606-1 SIPINNER SIGNAL 2FLAT CABLE
TEL 386-439612-3 SPINNER DC POWER CABLE
TEL 386-439680-5 SUM DRIVE CABLE (MATSUSHITA)
TEL 386-439956-3 M/A Y ENCODER ASSY (M4)
TEL 386-440044-1 MAP SENSOR (TR) ASSY
TEL 386-440472-2 SENSOR I/P BOARD
TEL 386-440786-2 CYLINDER SCAN I/O SENSOR
TEL 386-440791-2 SENSOR ASSY NOZZLE
TEL 386-441585-2 MOLEX 6P CABLE
TEL 386-442263-1 EE CCD LD ASSY
TEL 386-442566-2 SENSOR, 8 INCH WEE AXIS
TEL 386-442665-2 STEPPER I/F CABLE
TEL 386-442721-2 MOTOR, 8 INCH, WEE AXIS
TEL 386-442722-1 MOTOR, 8 INCH, WEE theta AXIS
TEL 386-443278-02 SPRING SUPPORT CABLE ASSY
TEL 386-443278-2 MA SPRING CABLE
TEL 386-4939426-3 M/A FLEX CABLE
TEL 387-400189-2 INDEXER SW HARNESS, 6 INCH
TEL 387-400319-1 LIQUID END DETECTOR
TEL 393-700670-4 ALARM ANALYZER BOX
TEL 3A-FN0104522 RORZE WAFER TRANSFER CERAMIC ARM
TEL 3AS0143010 AIR CYLINDER
TEL 3M10-101098-14 RING BASE
TEL 3M10-101101-12 PLATE,SUSCEPTER,3TAO
TEL 3M10-101182-11 CLAMP RING
TEL 3M10-101580-12 RING,ATTACHIMENT OP3
TEL 3M10-202183-12 TIN, 8IN NON CNT NO
TEL 3M10-307384-11 LIFTER PIN 300DSC WIDE
TEL 3M10-309663-11 QARTS PIN LIFTER 3TAO
TEL 3M10-405093-11 SPRING, FIT C-22
TEL 3M10-405839-11 C-RING BOTTOM COVER PIN 300
TEL 3M10-407411-11 STOPPER,COVER PIN
TEL 3M10-407431-11 HOLDER,SUSCEPTER,3TAO
TEL 3M10-407876-12 BOLT,SHOULDER SH
TEL 3M10-410242-11 PIN,SFR SUPPORT
TEL 3M10-410595-11 PIN,CB HOTLINER SUPP
TEL 3M10-451439-11 SHEET HEAT CONDUCTER-0.5
TEL 3M80-000727-13 TC
TEL 3M80-000728-13 TC
TEL 3M86-028633-11 CA,ASSY WTR LEAK,SHOWER
TEL 3M87-019502-12 ASSEMBLY, PV62 TRAP BACK VLV
TEL 3M87-029068-16 SHOWER ASSY,300TL
TEL 3M87-041475-11 PERTIER UNIVERSAL ASSY
TEL 3S10-401601-11 PIN,WAFER SUPPORT
TEL 3S80-000199-11 MANOMETER,1000 TORR
TEL 3S80-000200-11 MANOMETER,10 TORR
TEL 3S80-000307-11 ARC,300MM EDGE HEAT
TEL 3TB0006230 TIMING BELT 037-XL-0093A-J
TEL 3TB0038500 TIMING BELT FOR CDV GEN. USE 126X037
TEL 3TB0045110 TIMING BELT 150XL075
TEL 4-4-V1HBV1-SSR1.70-PE 1/4 VCR CLOSE COUPLING
TEL 410-217029-1 COMB, TRANSFERS
TEL 4103156213 COMB, PUSHER, 1
TEL 413182-002 RING
TEL 413182-006 RING
TEL 413182-008 RING
TEL 413182-009 RING
TEL 413182-010 RING
TEL 42755-0700 CU, KIT, SHIELD, SPUT
TEL 44B7767 EXTRACTION ELECTRODE INSULATOR
TEL 450001 VALVE MAKE UP WATER
TEL 47-442-VFS-P 1/4 VCR CLOSE COUPLING
TEL 481-501620-2 PCB, I/O COUNTER
TEL 481-501621-3 I/O DRIVER
TEL 481-501622-4 PCB, PCL8
TEL 481-600806-1 PCB, POWER CONNECT
TEL 481-600973-2 PCB, I/O ISOLATION
TEL 4815000915 PCB, TSBX, S10
TEL 4K2263 UPPER COOLING PLATE
TEL 5-39-02680 O-RING
TEL 5-4696-310A PCB
TEL 50-1762-001 PLATE, SHOWER QTZ SB
TEL 501-00-15 BOARD, SEMY GIF, SAFETY
TEL 501-00-78 PCB, FIRING BOARD
TEL 501-01-18 AMPLIFIER, TC TYPE R
TEL 501-01-30 PCB
TEL 501-01-34 PCB
TEL 501-01-35 PCB, EXTERNAL DIGITAL INPUT BOARD
TEL 501-01-47 PCB, BOAT LOADER INTERFACE
TEL 5010-202984-11 CHUCK(SS)
TEL 5010-210339-11 FORK(X1)
TEL 5010-210340-11 FORK(X2)
TEL 5010-210341-11 FORK(L)
TEL 5010-210342-11 FORK(R)
TEL 5010-316175-11 BAR(COT-D304)
TEL 5010-317625-11 BAR(TCT)
TEL 5010-410589-11 PACKING
TEL 5010-411333-11 PIN(COT-INNER)
TEL 5010-411843-11 PIN(COT-UPPER)
TEL 5010-412516-11 PIN, POSITION
TEL 5010-414421-11 PIN
TEL 5021350 CYL, HIVAC, LL, UHV
TEL 5022290 ACTUATOR,ROT,AIR,1"
TEL 505647 8 HOLE RING
TEL 5080-191952-11 LAMP
TEL 5085-401581-11 FORK ASSY.CRA
TEL 5085-427417-11 CHECK ASSY
TEL 518559 BELLOWS, BIG, UNITY II
TEL 54440-E039 PULSE MOTOR DRIVE UNIT( ROBOTARM)
TEL 550-061A QUARTZ RING A
TEL 564-307570 PCBOARD (MC31027&MC31026)
TEL 567-1138 ELECTROSTATIC LOADER ARM (CD-SEM)PHS
TEL 567-3619 CHUCK STAGE ASSEMBLY
TEL 600-1001-P30 CABLE
TEL 600-1002-P50 CABLE, RS485
TEL 600-1003-P1 CABLE
TEL 600-1008-P15 CABLE
TEL 6000-8546 PCB SYSTEM CO****OLLER BOARD SYS286CONT
TEL 697ZZ YUASA ROBOT BEARING
TEL 701B8 SPEED CO****OLLER
TEL 715-330135-001 GAS RING
TEL 715-46053-001 GROUNDING BLOCK,ELECTRODE,STRIP CHAMBER
TEL 715-8010522-001 BASE PLATE
TEL 7205477-0001 ANA LOCK CO****OLLER TYPE A/B
TEL 7310-3516-01 LAMP ANNEALTC WAFER 1501TYPE
TEL 780-05155-200 KIT,GEM/SECS II,V2.0,81XX
TEL 780136764 FILTER ELEMENT FA-550911UKWS70820
TEL 80-2010 BOARD, CIRCUIT
TEL 80-2030 BOARD, CIRCUIT
TEL 80-2040 PCB, ASSY, VALVE DRIVER
TEL 80-2060A BOARD, CIRCUIT
TEL 800140036 APERTURE 6.0ST1.5PJS
TEL 800213033 APERTURE MB101199(01)-6*0.02T0.5U(PART
TEL 800400930 RING CE**** NW100
TEL 8008743 ILLUMINATIONLAMP12V100WHLX64625
TEL 802050A BOARD, CIRCUIT
TEL 802050C BOARD, CIRCUIT
TEL 8043069G002 FREQUENCY CONVERTER
TEL 810-08727 EXHAUST RING, QUARTZ, 8K-ESC
TEL 810-120008-6 UPPER ELECTRODE BODY
TEL 810-120087-1 TE400 LOWER
TEL 810-120375-4 BODY ELECTRODE, UPPER. (CP11)
TEL 810-220047-8 UPPER CLEANING PLATE (D)
TEL 810-220135-1 OUTER GATE
TEL 810-220223-6 EXHAUST RING
TEL 810-220296-1 5"EXHAUST RING 5" (5-BL)
TEL 810-220333-2 RING, CLAMP 6" (JEIDA) (AL203)
TEL 810-220486-5 DEPO SHIELD
TEL 810-220666-2 DEPO SHIELD(8K) (ALUMINA)
TEL 810-220666-4 SHIELD
TEL 810-220689-1 PLATE, BAFFLE
TEL 810-220690-2 PLATE, BAFFLE
TEL 810-220725-2 EXHAUST RING (6-BL)
TEL 810-220734-1 COOLING PLATE (C-11)
TEL 810-220734-2 EXHAUST RING
TEL 810-320013-6 UPPER INSULATOR
TEL 810-320068-1 BAFFLE H
TEL 810-320069-1 BAFFLE
TEL 810-320252-2 SENSOR HOUSING
TEL 810-320259-1 GUARD RING
TEL 810-320310-3 VACUUM TWEEZERS
TEL 810-320648-2 CERAMIC RING
TEL 810-321095-1 A 1070 FOCUS RING
TEL 810-321139-1 GUARD RING
TEL 810-321230-1 BAFFLE (BX-1)
TEL 810-321231-1 BAFFLE
TEL 810-321311-2 YMS-9600
TEL 810-321311-4 WAFER LIFTER B
TEL 810-321369-3 WAFER HOLDER
TEL 810-321371-4 H/A PIN SET (8)
TEL 810-321640-1 GUARD RING(8K-ESC)
TEL 810-321649-4 VACUUM PIN SET 2
TEL 810-321735-5 ELECTRODE SHIELD RING
TEL 810-400034-1 ADJUST PIN
TEL 810-420062-1 SUPPORT
TEL 810-420063-4 WINDOW
TEL 810-420072-1 LANTERN RING
TEL 810-420074-1 WASHER (PACK OF 10)
TEL 810-420075-3 LIFTER SPRING
TEL 810-420129-1 BAFFLE
TEL 810-420139-1 CLAMP SHAFT DAMPER
TEL 810-420149-1 CERAMIC PIN
TEL 810-420158-4 WAFER LIFTER
TEL 810-420168-1 SUPPORT GUIDE
TEL 810-420174-2 LIFTER SUPPORT
TEL 810-420190-1 GATE ROLLER
TEL 810-420210-1 COLLAR 4- 5.6
TEL 810-420212-1 RING, LENTERN A
TEL 810-420321-1 CYLINDER END
TEL 810-420323-1 GUIDE SHAFT
TEL 810-420326-1 REAR WINDOW
TEL 810-420526-1 PLUG (S) (PACK OF 10)
TEL 810-420526-1* PLUG (S)
TEL 810-420595-1 RF CONNECTOR
TEL 810-420605-2 GAS INLET 92 S
TEL 810-420715-1 GATE CONNECT BLOCK
TEL 810-420776-1 INNER BLOCK SPACER
TEL 810-420812-1 TEMP SENSOR HOLDER (BN)
TEL 810-420967-2 CONNECTOR SUPPORT
TEL 810-420986-1 RF ADAPTER
厦门海通华业科技有限公司 > 铝产品 > 2986-401217-12山东
