26-0200-271四川
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
O****AK 22-5100-004 PCB, ASSY, SMIF-ARM INTERFACE BD
O****AK 22-8875-005 PCB, BD QUAD MICRO STEPPER
O****AK 220-016 PULLEY, GROOVED
O****AK 25-0001-003 TOOL,.125 SHIM
O****AK 26-0200-032 KIT, SPARE PARTS, DSS-200, W/MEG
O****AK 26-0200-207 KIT, ANNUAL, O****AK, S21
O****AK 26-0200-212 KIT, QUARTERLY, O****AK, S21
O****AK 26-0200-215 KIT, BRUSH, SEMI-ANNUAL PM, S2i
O****AK 26-0200-262 PM KIT QUARTERLY
O****AK 26-0200-269 KIT,ANNUAL,PM,INTEL,CE96
O****AK 26-0200-270 KIT SEMIANNUAL PM CE96
O****AK 26-0200-271 KIT, QUARTERLY, PM,CE96
O****AK 26-0200-383 PM KIT, SERIES 1
O****AK 26-0200-385 PM KIT, SERIES 1
O****AK 26-0200-387 QUARTERLY PM, SERIES 0&1 KIT
O****AK 26-0200-388 KIT, PM, ANNUAL, SPIN, S0&1
O****AK 26-0200-391 KIT, PM, ANNUAL, OUTPUT, S0&1
O****AK 26-0200-399 PM KIT, SERIES 2, Q3
O****AK 26-0200-400 PM KIT, SERIES 2, Q4
O****AK 26-0200-401 QUARTERLY PM, S2 CLASSIC
O****AK 26-0200337 KIT,PMQ2CE
O****AK 26-2725-400 KIT,PMQ1CE,WSCRUB/ERGO,L0ADR
O****AK 26-2725-500 KIT,PMQ2CE,WSCRUB/ERGO,LOADR
O****AK 26-2725-700 KIT,PMQ4CD,WSCRUB/ERGO,LOADR
O****AK 26-8800-005 KIT, TRANSPORT ROLLER 4 BR
O****AK 26-8800-006 KIT, TRANSPORT ROLLER 5 BR
O****AK 26-8800-014 KIT PM QRTLY BRUSH ****
O****AK 26-8800-118 KIT, PM, SEMI-ANNUAL, BR. UPPER, SYN
O****AK 26-8800-119 KIT,LOWER,BRUSH,SEMI-ANNUAL
O****AK 26-8800-120 KIT,BR,ROLLER,SEMI-ANNUAL
O****AK 26-8800-144 KIT, PMSCEBRSH8800-038
O****AK 26-8800-145 KIT,SEMI-ANNUAL,PM,CE96
O****AK 26-8882-009 KIT,SPIN,SEMI-ANNUAL PM
O****AK 26-8882-010 KIT CARRIAGE ROLLER
O****AK 26-8882-011 KIT, IDLER ROLLER
O****AK 26-8882-054 KIT,PMACESPIN8882-027
O****AK 26-8882-055 KIT, PMSCESPIN8882-027
O****AK 26-8882-059 IT, PM,SEMI-ANNUAL, SPIN, INT
O****AK 26-8882-060 KIT PM QRTLY SPIN ****
O****AK 26-8882-070 KIT, RETROFIT,SPINNING,S2
O****AK 26-8882-079 KIT, PM, SEMI ANNUAL, SPIN, S2C
O****AK 26-8892-003 KIT,SENDER,SEMI-ANNUAL PM
O****AK 26-8892-009 KIT CNVYR TRANS DRIVE
O****AK 26-8892-062 KIT, PM, SEMI-ANNUAL, INPUT, INT
O****AK 26-8892-065 KIT,ANNUAL,PM
O****AK 26-8892-066 KIT, PMSCE INPT 8892-040
O****AK 26-8892-077 KIT, PM, ERGO,ANNUAL,S2
O****AK 26-8892-078 KIT, PM, ERGO, SEMIANN, S2
O****AK 26-9900-009 PM, KIT, INTEGRA, Q-4
O****AK 2600-8800-004 KIT,BR SEMI ANNUAL PM, S2
O****AK 27-0001-042 WRENCH,TAP,3/8"SQ DR.1/4"-1/2"
O****AK 27-0001-043 TAP AND DRILL,COMB,7/16-20UNF
O****AK 28-0001-002 ASSY,PIA TEST PCB BD.
O****AK 28-0001-004 ASSY, PCB PIA INDICATOR
O****AK 28-0075-012 PCB INTERFACE ASSY
O****AK 28-0075-014 PCB ASSY PRINTER SO
O****AK 28-8875-002 PCB
O****AK 28-8875-004 P.C.B.
O****AK 28-8875-005 PCB, BD QUAD MICRO STEPPER
O****AK 28-8875-011 PCB, ASSY OUTPUT INTERFACE
O****AK 28-8875-012 PCASSY, COMM, PRE-PROD.
O****AK 28-8875-013 PCB, DUAL DC MOTOR
O****AK 28-8875-014 PCB, QUAD MICRO STEPPER
O****AK 28-8875-035 PCB,ASSY,DIST
O****AK 28-8875-037 OPTO, INPUT BD
O****AK 28-8875-038 PCB, SMIF
O****AK 28-8875-045 ASSY,PC,INT,MOTOR
O****AK 28-9975-006 DISTRIBUTION MOTHER BOARD ASSY
O****AK 30-0008-001 POWER SUPPLY, 120V (SSI)
O****AK 30-0008-003 O-RING
O****AK 30-0008-008 O-RING
O****AK 30-0008-015 O-RING,.737IDX.103W,VITON
O****AK 30-0008-018 O-RING,2.3IDx .103W,POLYURETHAN
O****AK 30-0008-020 O-RING, .299 ID, .505 OD, PO
O****AK 30-0008-024 O-RING
O****AK 30-0008-027 O-RING, 2.237 X.103
O****AK 30-0008-028 O-RING, 2.800 ID X .103
O****AK 30-0008-030 O-RING,2-006,CLEAR
O****AK 30-0008-049 O-RING,209 ID,.070W
O****AK 30-0008-052 O-RING
O****AK 30-0008-070 O-RING,2-031
O****AK 30-0008-083 O-RING,.989ID,.070W,U66270
O****AK 30-0008-107 O-RING (PACK OF 4)
O****AK 30-0024-221 FTG,"Y",1/8 O.D.
O****AK 30-0056-021 COUPLER,FLEX,3/8X1/4
O****AK 31-0004-046 VALVE, PNEUMATIC 5 PORT
O****AK 31-0007-003 VALVE, PNEU, W/MICRO ADJ
O****AK 31-0008-002 CYLINDER, ROLLER,SOL,4,S0
O****AK 31-0008-003 CYLINDER, LARGE
O****AK 31-0008-011 CYLINDER, AIR SEND
O****AK 31-0008-019 CYLINDER, AIR, 9/16,BORE,2
O****AK 31-0008-026 CLEVIS,AIR CYLINDER PISTON
O****AK 31-0009-004 MOUNT, FRAME
O****AK 31-0009-012 CLEVIS, REAR
O****AK 31-0010-001 CYLINDER, ROLLER
O****AK 31-0010-002 CYLINDER,ROLLER,SOL,2
O****AK 31-0010-003 CYLINDER-4 STROKE
O****AK 31-0010-006 PLUG, 1.4NPT
O****AK 31-0010-015 CYLINDER, ROTA, XPORT, ERGO
O****AK 31-0011-002 VALVE, E****Y, EXIT
O****AK 32-0003-007 TIMING BELT
O****AK 32-0003-008 TIMING BELT
O****AK 32-0003-009 TIMING BELT
O****AK 32-0003-019 BELT, ROLLER BRUSH
O****AK 32-0005-002 CHAIN DRIVE
O****AK 32-8000-004 ARM, TIMING BELT, URETHANE, R
O****AK 33-0002-003 BEARING,ROBOT,WRIST
O****AK 33-0002-008 BEARING
O****AK 33-0002-010 BEARING .7874 ID ROBOT, ROTN, FRONT
O****AK 33-0002-028 BEARING CARRIAGE CAP FT 2
O****AK 33-0002-029 BEARING,.CARRIAGE,BK,2
O****AK 33-0002-034 BEARING,FLANG,5/8IDX23/3
O****AK 33-0002-036 BEARING,FLANG 1/2IDX19/3
O****AK 33-0002-044 BEARING, THRUST
O****AK 33-0003-001 BUSHING, WRIST,ROBOT
O****AK 33-0004-027 SEAL,DYNAMIC,3/4 SHAFT
O****AK 33-0004-029 SEAL, RECIP. 5/8" SHAFT (PACK OF 4)
O****AK 33-0004-041 SEAL,DYNAMIC,.25 SHAFT
O****AK 33-0004-042 SEAL ROTARY 5/8
O****AK 33-0004-045 SEAL, ROTARY
O****AK 33-0007-003 SHAFT, 1/4", DIA - 2 INCH
O****AK 33-0008-023 BUSHING,FLANGED,.75 SHAFT
O****AK 33-0014-003 BEARING, BALL, 5/8OD, CAMF, SPIN
O****AK 33-0092-001 LINER GUIDEWAY
O****AK 33-1000-005 BRG, DEL. GLASS BALLS
O****AK 35-0005-001 FLOWMTR,TEFO- 1
O****AK 35-0005-007 CO****OL, FLOW
O****AK 35-0005-011 FLOWMETER, 1000-4000CC,FLA
O****AK 35-0005-012 FLOW METER
O****AK 35-0005-014 FLOWMETER 5-250 CC., FLARE
O****AK 35-0005-024 FLOWMETER, TEF, 350-1500CC
O****AK 35-8000-001 FLOWMETER
O****AK 40-0075-007 POWER SUPPLY 5VDC /- 12VDC 25
O****AK 40-0075-008 POWER SUPPLY
O****AK 42-0007-005 MOTOR, STEPPER, CASS, RECEIVER, ST
O****AK 42-0007-10 2P MICRO STEP DRIVER, RD-021M8
O****AK 42-0010-004 CO****OLLER-SEMIX MICROCOMPTER
O****AK 42-0960-ABT REMOTE ABORT KEYPAD
O****AK 42-0960-RTA REMOTE ARM TRANSFER PAD
O****AK 42-2289-000 CO****OL BOARD
O****AK 43-0003-004 VALVE, N/C, SST DIAPHRAGM
O****AK 44-0080 ROD
O****AK 44-0499 PLATE
O****AK 44-1524 CONNECTOR
O****AK 44-3302 IONIZATION GAUGE TUBES 11.5 TORR (SIGNET)
O****AK 50-0075-007 EPROM, GESPAC 128K X 8 155NS
O****AK 70-0010-022 CONTACT SCKT,18-16GA (PACK OF 10)
O****AK 70-0010-024 CONTACT SCKT,20-24GA (PACK OF 10)
O****AK 70-0010-091 CONNECTOR,6POS.,PIN
O****AK 70-0010-096 CONNECTOR,6POS,#16PIN,CE
O****AK 70-0010-101 CONNECTOR, 4 POS, #16 PIN, CE
O****AK 70-0010-127 CONNECTOR,6POS,#20PIN,CE
O****AK 70-0010-162 CONN,PLUG,CPC 14-7,REV.SEX
O****AK 70-0024-001 CO****OLLER SOCKET .084 20-14AWG 94V
O****AK 70-0364-00 ENCORDER WHEEL ASSY
O****AK 72-0005-009 SWITCH, INDK, PSHBTM, LT
O****AK 73-0001-001 LAMP, QUARTZ, 1000W
O****AK 73-0001-010 LAMP, HALOGEN, 120V
O****AK 73-0006-005 BULB, TOWER, ERGO
O****AK 76-0002-001 NOZZLE, SPRAY, DSS, 0/2
O****AK 80-0002-002 SCANNER
O****AK 80-0002-003 FIBER CABLE
O****AK 80-0002-004 SENSOR AMPLIFIER
O****AK 80-0002-009 SENSOR, WAFER,LOWER, BRUSH
O****AK 80-0002-010 SENSOR, SOCKET
O****AK 80-0002-015 SENSOR, CAP. PROXIMITY, E2K-X4ME1
O****AK 80-0002-024 SENSOR AMPLIFIER MEGASONIC
O****AK 80-0002-028 ACTUATOR,MAG POSITION
O****AK 80-0002-029 OPTIC, SPIN, THRUBEAM,2
O****AK 80-0002-034 SENSOR MINI BEAM
O****AK 80-0002-042 FIBER, OPTIC, RECEIVE,CIP,2
O****AK 80-0002-047 SENSOR,HALL EFFECT,CL
O****AK 80-0002-052 SENSOR, PHOTOMICROSENSOR T
O****AK 80-0002-053 SENSOR, CAP PROXIMITY, E2K-X4ME2
O****AK 80-0002-057 SENSOR
O****AK 80-0002-059 SENSOR,PROBE,SINGLE CHANNEL
O****AK 80-0002-067 SENSOR,HALL EFFECT PN
O****AK 86-000-08200 WASHERS (PACK OF 10)
O****AK 90-0033-040 WSHR, FLT, 5/8 (PACK OF 4)
O****AK 91-0006-017 RING, RTNG, EXT,.75,SS
O****AK 92-0001-010 SPACER-SHAFT .375 X .56 (PACK OF 10)
O****AK 92-0001-011 SPACER,SHAFT,ROBOT
O****AK 92-0001-027 SPACER, SHAFT, .187ID, SPIN
O****AK 950182 SHAFT,DISK,PAD COND
O****AK 951645 ASSY,LOAD CELL CABLE
O****AK 99-00303 ASSEMBLY, PULLEY
O****AK 99-01602 SPINDAL HARNESS ASSY
O****AK 99-04013 MOTOR
O****AK 99-04187 AMP
O****AK 99-06082-01 MOTOR LIFT
O****AK 99-80207-02 PCB,90S,SPIN,STA,EXPANS
O****AK SP100CCF PHOTO ELECTRIC SWITCH (BANNER)
O****AK SP100CF SENSOR,MEGASONIC
O****AK SP100DB SENSOR SP100DB DIFFUSE SENSOR
O****AK SP100R SENSOR (BANNER)
OPTO 22 120D10 RELAY SS 120VAC 10A
OPTO 22 240D25 RELAY 3-32 V SSR
OPTO 22 240D45 RELAY 3-32 V 45A SSR (OPTO 22)
OPTO 22 AC28 PCB, 4 DRIVER OPTO 22
OPTO 22 AD5T MODULE, TC, INPUT
OPTO 22 G4D16R BRICK. DISCRETE. 16CH
OPTO 22 G4DI6R BRICK. DISCRHTE.16CH
OPTO 22 G4IDC5 MODULE, INPUT, ISO
OPTO 22 G4ODC5 MODULE, OUTPUT, ISO
OPTO 22 G4PB32DEC I/O MODULE MOUNTING RACK
OPTO 22 G4RA BRAINBOARD ANALOG 16CH
OPTO 22 G4RD BRAINBOARD ANALOG
OPTO 22 PB-24Q PCB I/O MOUNT RACK (GORDOS ARKANSAS)
OPTO 22 PB16H PCB, I/O MODULE MOUNTING RACK
OPTO 22 PB24HQ PCB BOARD
OPTO 22 PB24Q PCB
OPTO 22 PB32DEC PCB ASSY
OPTO 22 PB32HQ MOUNTING RKCKS
OPTO 22 PB32P2 PC BOARD I/O OPTO 22
OPTO 22 SNAP-AIV-4 ANALOG, 4 CHANNEL S
ORIENTAL MOTOR 0-06-B5342-9 WAFER GUIDE PVC CENTERING TRANSPORT
ORIENTAL MOTOR 0-39-04044 TIMING BELT  DR01 032SCR TOOTHED BELT
ORIENTAL MOTOR 01K3GN-B MOTOR
ORIENTAL MOTOR 0GK180K GEARHEAD
ORIENTAL MOTOR 0GK18K-D1 GEAR HEAD
ORIENTAL MOTOR 0GK3K GEAR HEAD (PX809480)
ORIENTAL MOTOR 0GN12.5K GEAR HEAD
ORIENTAL MOTOR 0GN18K GEAR HEAD
ORIENTAL MOTOR 0IK3GK-B3 MOTOR
ORIENTAL MOTOR 1052-205 2 PHASE MOTOR
ORIENTAL MOTOR 110E1-J41-PLLN VALVE SOLENOID
ORIENTAL MOTOR 140804-0700-082 PULSE MOTOR UNIT
ORIENTAL MOTOR 1843-424 REVERSIBLE MOTOR
ORIENTAL MOTOR 21K6RGK-A2 INDUCTION MOTOR (51822)
ORIENTAL MOTOR 21K6RGN-A SPEED CO****OL MOTOR
ORIENTAL MOTOR 29K36K GEAR HEAD
ORIENTAL MOTOR 2GA180K GEAR HEAD (PV812092)
ORIENTAL MOTOR 2GB100K GEAR HEAD (ORIENTAL MOTOR)
ORIENTAL MOTOR 2GB36K GEAR HEAD (ARM)
ORIENTAL MOTOR 2GB75K GEAR HEAD (ORIENTAL MOTOR)
ORIENTAL MOTOR 2GB90K GEAR HEAD
ORIENTAL MOTOR 2GK100K MOTOR, GENR HEAD
ORIENTAL MOTOR 2GK150K GEAR HEAD (509D25)
ORIENTAL MOTOR 2GK15K GEAR HEAD
ORIENTAL MOTOR 2GK180K GEAR HEAD
ORIENTAL MOTOR 2GK18K GEAR HEAD
ORIENTAL MOTOR 2GK30 MOTOR
ORIENTAL MOTOR 2GK30K GEAR HEAD
ORIENTAL MOTOR 2GK30KA GEAR HEAD
ORIENTAL MOTOR 2GK36K GEAR HEAD
ORIENTAL MOTOR 2GK3K GEARHEAD
ORIENTAL MOTOR 2GK50K GEAR HEAD
ORIENTAL MOTOR 2GK6 GEAR HEAD FOR TPC
ORIENTAL MOTOR 2GK75K GEAR HEAD
ORIENTAL MOTOR 2GN100K MOTOR
ORIENTAL MOTOR 2GN10XK MOTOR
ORIENTAL MOTOR 2GN150K GEAR HEAD
ORIENTAL MOTOR 2GN15K GEAR HEAD
ORIENTAL MOTOR 2GN180K GEAR HEAD (PUSHER)
ORIENTAL MOTOR 2GN18K GEAR HEAD
ORIENTAL MOTOR 2GN25K GEAR HEAD
ORIENTAL MOTOR 2GN30K GEAR HEAD 808F19
ORIENTAL MOTOR 2GN30KA GEAR HEAD
ORIENTAL MOTOR 2GN36K GEAR HEAD (ORIENTAL MOTOR)
ORIENTAL MOTOR 2GN9K GEAR HEAD (ORIENTAL MOTOR)
ORIENTAL MOTOR 2IK6GN-A INDUCTION MOTOR
ORIENTAL MOTOR 2IK6RGK-A2 REVERSIBLE MOTOR
ORIENTAL MOTOR 2RJ4GA-A2 REVERSIBLE MOTOR
ORIENTAL MOTOR 2RJ4GB-A REVERSIBLE MOTOR
ORIENTAL MOTOR 2RJ4RGB-A C/W NOZZLE REVERSIBLE DRIVE MO
ORIENTAL MOTOR 2RK6GK-A2 MOTOR, DRIVE, FOR A/L, 2RK6GK
ORIENTAL MOTOR 2RK6GK-AA REVERSIBLE MOTOR
ORIENTAL MOTOR 2RK6GK-AM REVERSIBLE MOTOR
ORIENTAL MOTOR 2RK6GN-A REVERSIBLE MOTOR
ORIENTAL MOTOR 2RK6GN-AM AC MAGNETIC BRAKE MOTOR
ORIENTAL MOTOR 2RK6GN-C REVERSIBLE MOTOR
ORIENTAL MOTOR 2RK6RGN-A SPEED CO****OL MOTOR
ORIENTAL MOTOR 2RK6RGN-AM MOTOR,AC MAG. BRAKE SP CO****OL
ORIENTAL MOTOR 2RK6RGN-C MOTOR
厦门海通华业科技有限公司 > 铝产品 > 26-0200-271四川
