ACOPOSmicro驱动系统
ACOPOSmicro为低功耗应用提供多达2轴驱动模块。ACOPOSmicro旨在控制步进电机和伺服电机。
- 应用广泛
- 集成I/O
- 设计紧凑
- 低功耗
- 逆变和步进电机模块统一设计
主营:力士乐电磁阀,ATOS比例阀,PARKER柱塞泵,DUPLOMATIC齿轮泵,VICKERS叶片泵,BENTLY传感器,AIRTEC机械阀,AVENTICS气动阀
上海 上海
16800元/个(大量采购价格面议)
贝加莱ACOPOSmicro伺服驱动器
| 物料号 | 描述 |
| 80VD100PD.C000-01 | ACOPOSmicro inverter module, POWERLINK interface, 2x EnDat 2.2, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks and encoder backup battery 80XB120A2.36-00 separately! |
| 80VD100PD.C000-14 | ACOPOSmicro inverter module, POWERLINK interface, 2x EnDat 2.2, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital input 24 VDC, sink, 2 digital outputs 24 VDC, 1 A, order terminal blocks and encoder backup battery 80XB120A2.36-00 separately! |
| 80VD100PD.C022-01 | ACOPOSmicro inverter module, X2X POWERLINK interface, 2x resolver, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PD.C022-14 | ACOPOSmicro inverter module, POWERLINK interface, 2x resolver, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital input 24 VDC, sink, 2 digital outputs 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PD.C033-01 | ACOPOSmicro inverter module, POWERLINK interface, 2x SSI absolute encoder, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PD.C088-01 | ACOPOSmicro inverter module, POWERLINK interface, 2x SinCos encoder, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PD.C144-01 | ACOPOSmicro inverter module, X2X POWERLINK interface, 2x incremental encoders, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PD.C188-01 | ACOPOSmicro inverter module, X2X POWERLINK interface, 2x LinMot®, 24-64 VDC ±25% power supply, 2 motor connections, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PS.C00X-01 | ACOPOSmicro inverter module, POWERLINK interface, 1x EnDat 2.2, 24-64 VDC ±25% power supply, 1 motor connection, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks and encoder backup battery 80XB120A2.36-00 separately! |
| 80VD100PS.C02X-01 | ACOPOSmicro inverter module, X2X POWERLINK interface, 1x resolver, 24-64 VDC ±25% power supply, 1 motor connection, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PS.C03X-01 | ACOPOSmicro inverter module, POWERLINK interface, 1x SSI absolute encoder, 24-64 VDC ±25% power supply, 1 motor connection, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
| 80VD100PS.C08X-01 | ACOPOSmicro inverter module, POWERLINK interface, 1x SinCos encoder, 24-64 VDC ±25% power supply, 1 motor connection, 8 A continuous current, 2 digital inputs 24 VDC, sink, can be used as trigger inputs, 1 digital output 24 VDC, 1 A, order terminal blocks separately! |
贝加莱逆变控制器伺服驱动器型号
贝加莱电源模块
贝加莱柜内安装
8BVP0220HW00.000-1
8BVP0440HW00.000-1
8BVP0880HW00.004-1
8BVP1650HW00.000-1
贝加莱冷却板或穿墙式安装
8BVP0220HC00.000-1
8BVP0440HC00.000-1
8BVP0880HC00.004-1
8BVP1650HC00.000-1
贝加莱辅助电源模块 400W
贝加莱柜内安装
8B0C0160HW00.000-1
8B0C0160HW00.001-1
贝加莱冷却板或穿墙式安装
8B0C0160HC00.000-1
8B0C0160HC00.001-1
贝加莱辅助电源模块 800W
贝加莱柜内安装
8B0C0160HW00.A01-1
8B0C0320HW00.000-1
8B0C0320HW00.002-1
8B0C0320HW00.00A-1
贝加莱冷却板或穿墙式安装
8B0C0160HC00.A01-1
8B0C0320HC00.000-1
8B0C0320HC00.002-1
8B0C0320HC00.00A-1
贝加莱逆变模块(单轴模块)
贝加莱柜内安装
8BVI0014HWS0.000-1
8BVI0028HWS0.000-1
8BVI0055HWS0.000-1
8BVI0110HWS0.000-1
8BVI0220HWS0.000-1
8BVI0330HWS0.000-1
8BVI0440HWS0.000-1
8BVI0660HWS0.000-1
8BVI0880HWS0.004-1
8BVI1650HWS0.000-1
贝加莱冷却板或穿墙式安装
8BVI0014HCS0.000-1
8BVI0028HCS0.000-1
8BVI0055HCS0.000-1
8BVI0110HCS0.000-1
8BVI0220HCS0.000-1
8BVI0330HCS0.000-1
8BVI0440HCS0.000-1
8BVI0660HCS0.000-1
8BVI0880HCS0.004-1
8BVI1650HCS0.000-1
贝加莱逆变模块, SafeMOTION (单轴模块)
贝加莱柜内安装
8BVI0014HWSA.000-1
8BVI0014HWSS.000-1
8BVI0028HWSA.000-1
8BVI0028HWSS.000-1
8BVI0055HWSA.000-1
8BVI0055HWSS.000-1
8BVI0110HWSA.000-1
8BVI0110HWSS.000-1
8BVI0220HWSA.000-1
8BVI0220HWSS.000-1
8BVI0330HWSA.000-1
8BVI0330HWSS.000-1
8BVI0440HWSA.000-1
8BVI0440HWSS.000-1
8BVI0660HWSA.000-1
8BVI0660HWSS.000-1
8BVI0880HWSA.004-1
8BVI0880HWSS.004-1
8BVI1650HWSS.000-1
贝加莱冷却板或穿墙式安装
8BVI0014HCSA.000-1
8BVI0014HCSS.000-1
8BVI0028HCSA.000-1
8BVI0028HCSS.000-1
8BVI0055HCSA.000-1
8BVI0055HCSS.000-1
8BVI0110HCSA.000-1
8BVI0110HCSS.000-1
8BVI0220HCSA.000-1
8BVI0220HCSS.000-1
8BVI0330HCSA.000-1
8BVI0330HCSS.000-1
8BVI0440HCSA.000-1
8BVI0440HCSS.000-1
8BVI0660HCSA.000-1
8BVI0660HCSS.000-1
8BVI0880HCSA.004-1
8BVI0880HCSS.004-1
8BVI1650HCSS.000-1
贝加莱逆变模块(双轴模块)
贝加莱柜内安装
8BVI0014HWD0.000-1
8BVI0028HWD0.000-1
8BVI0055HWD0.000-1
8BVI0110HWD0.000-1
8BVI0220HWD0.000-1
贝加莱冷却板或穿墙式安装
8BVI0014HCD0.000-1
8BVI0028HCD0.000-1
8BVI0055HCD0.000-1
8BVI0110HCD0.000-1
8BVI0220HCD0.000-1
贝加莱逆变模块, SafeMOTION (双轴模块)
贝加莱柜内安装
8BVI0014HWDS.000-1
8BVI0028HWDS.000-1
8BVI0055HWDS.000-1
8BVI0110HWDS.000-1
8BVI0220HWDS.000-1
贝加莱冷却板或穿墙式安装
8BVI0014HCDS.000-1
8BVI0028HCDS.000-1
8BVI0055HCDS.000-1
8BVI0110HCDS.000-1
8BVI0220HCDS.000-1
贝加莱扩展模块
贝加莱柜内安装
8BVE0500HW00.000-1
贝加莱冷却板或穿墙式安装
8BVE0500HC00.000-1
贝加莱电容模块
贝加莱柜内安装
8B0K1650HW00.000-1
8B0K3630HW00.001-1
贝加莱冷却板或穿墙式安装
8B0K1650HC00.000-1
8B0K3630HC00.001-1
贝加莱制动电阻
8B0W0045H000.000-1
8B0W0045H000.001-1
8B0W0079H000.000-1
8B0W0079H000.001-1
贝加莱插入式模块
8BAC0120.000-1
8BAC0120.001-2
8BAC0121.000-1
8BAC0122.000-1
8BAC0123.000-1
8BAC0123.001-1
8BAC0123.002-1
8BAC0124.000-1
8BAC0125.000-1
8BAC0130.000-1
8BAC0130.001-1
8BAC0132.000-1
8BAC0133.000-1
意大利阿托斯ATOS以及意大利迪普马DUPLOMATIC、美国Parker派克及EATON VICKERS伊顿 威格士液压、日本YUKEN油研泵阀优势现货系列(电磁阀换向阀、压力开关、柱塞泵、齿轮泵、比例阀、截止阀、开关阀等),
奥地利贝加莱B&R br-automation自动化配品配件(伺服驱动器、触摸屏、工控机、CPU模块、总线控制器、X20\2003\2005\2010系统中各类功能模块等)
另销售 德国爱尔泰克AIRTEC气动电磁阀 美国本特利内华达BentlyNevada电源模块 延伸电缆 前置传感器 德国贝加福B&F等系列进口品牌
上海韦米机电设备有限公司
何洋 (联系时请告诉我是"铝道网看到的 信息,会有优惠哦!谢谢!)
1875691081@qq.com
上海市浦东新区新金桥路金豫路100号禹洲金桥国际2期2号楼1118室
¥800 元
¥800 元
¥9800 元
¥5100 元
