主营:铝带/片+镍片/带+铝镍复合带
江苏 无锡
面议(大量采购价格面议)
惠华产品: 1、 镍层硬度HV小于80的全软态铝镍复合材料。(也可用于过渡焊接) Ni- clad-Al strips (Ni :HV80-220) Mild soft Nickel-Aluminium Clading material with hardness of Nickel plating layer less than 80HV. 2、 低内阻镍带/片。惠华工程技术人员通过对镍成分的改良,成功的研制出电阻率为7.6的镍带。(一般镍带为8.6左右)惠华镍带比普通镍带低了15%左右。 Nickel strips/plate with low elecity resistance. We make out nickel strips with elecity resistance rate 7.6 after adjusting content of the nickel by Huihua’s technician, while that of normal one 8.6, thus it’s lower than ordianary one. 3.聚合物电池和软包装电池用镍/铝较耳。Nickel/Aluminium tags for Li-polymer &soft-packing battery. 采用大日本印刷灰胶Adopt epoxy hardener from Dai Nippon Printing Co., Ltd 日本进口铝带表面处理技术。Adopt Japanese surface treatment technology for Aluminum strips 备注:转让软包装电池(聚合物)电池较耳,全套生产技术(供应铝带表面处理液,日本进口较耳胶DNP,较耳热压机) 4.锂电池专项使用铝带。Aluminium strip specially for Li-ion battery.(已钝化处理可直接贴胶) 5.镍铜复合带/镍铁复合带等其他金属复合材料。Other metal-cladding material such as Ni-clad-Cu strips/Ni-clad-Fe strips
