供应高低温冲击箱
高低温冲击箱
thermonics冷热温度冲击系统
features
·fast temperature response time
·temperature range of -90c to +225c
·environmentally safe
·fully grounded·small footprint
·fast dut temperature stabilization time·color lcd display with touch-screen, operator interface
·flexible ate communications
·sophisticated system self diagnostics
·±1c accuracy with 0.1c readout
·motorized support arm
·high air flow rate·frost free operation·graphical display of temperature response
general description
method of cooling: forced air with single-stage mechanicalrefrigeration and multi-stage self-cooling heat exchanger. non-cfcbased refrigerants are used - environmentally safe.method of heating: forced air with in-line air heaters.operator interface: color lcd display, menu-driven touch-screenwith software menu selections. software contains system selfdiagnostics. uses graphical software to select system menus such asoperating mode, and to set system parameters such as temperaturesetpoint or flow rate.data communications: interfaces to ate systems. contains ieee-488.2, rs-232c, standard tester interface, and printer ports. softwarecommunication parameters are configurable to accommodate varyingsystems.
system featurestemperature sensor: device under test (dut), k-type and t-typethermocouples. also, k-type thermocouple for air temperature.controller: an 80x86, ms-dos based microcomputer.fail safes: snap-disc thermostats, air flow sensors andthermocouples. over-temperature limit of 245c.
本产品来源于 无锡优联测控技术有限公司http://www.wxylck.com
产品导航: 盐雾腐蚀试验箱 高低温试验箱 高低温交变试验箱 高低温湿热试验箱 高低温交变湿热试验箱 恒温恒湿试验箱 移动式冷热冲击试验箱 固定式冷热冲击试验箱 沙尘试验箱 淋雨试验箱箱 淋雨试验装置 臭氧老化试验箱 紫外光耐气候试验箱 氙灯耐气候试验箱 步入式恒温恒湿试验箱 大型烘箱 电磁振动台 温湿度振动综合试验箱 耐气候循环试验箱 高温高湿试验机 耐紫外辐照试验机 煮沸试验箱 鼓风干燥箱 恒温恒湿箱 生化培养箱 老化试验箱 二氧化碳培养箱 光照培养箱 回旋振荡器 电热恒温水浴锅
无锡优联测控技术有限公司 > 铝产品 > 供应高低温冲击箱
