供应单晶炉水冷电缆3
<p class="MsoNormal" style="margin: 0cm 0cm 0pt; line-height: 25pt; mso-line-height-rule: exactly;"><span style="font-size: 14pt;"><span style="mso-spacerun: yes;"> </span></span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman"; mso-no-proof: yes;">①</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">电较(俗称电缆头)是无触点、无焊点、无焊缝。有两种结构形式,一种是用整根铜棒在数控车床、铣床上加工而成,表面经过镀锡处理,美观、耐用、电阻小。另一种是空心结构,特点是电较也能通水冷却,适用承载大电流,工作时不会发热,已广泛用于单晶炉设备。</span><span style="font-size: 14pt;" lang="EN-US"></span></p> <p class="MsoNormal" style="margin: 0cm 0cm 0pt; text-indent: 28pt; line-height: 25pt; mso-line-height-rule: exactly; mso-char-indent-count: 2.0;"><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman"; mso-no-proof: yes;">②</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">所用外护套管是从橡胶厂定做的专项使用优异胶管,外径</span><span style="font-size: 14pt; font-family: 宋体;">Φ</span><span style="font-size: 14pt;" lang="EN-US">51mm</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">,内径</span><span style="font-size: 14pt; font-family: 宋体;">Φ</span><span style="font-size: 14pt;" lang="EN-US">38mm</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">,耐工作水压</span><span style="font-size: 14pt;" lang="EN-US">0.6MPa</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">、耐击穿电压</span><span style="font-size: 14pt;" lang="EN-US">2300V</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">。</span><span style="font-size: 14pt;" lang="EN-US"></span></p> <p class="MsoNormal" style="margin: 0cm 0cm 0pt; text-indent: 28pt; line-height: 25pt; mso-line-height-rule: exactly; mso-char-indent-count: 2.0;"><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman"; mso-no-proof: yes;">③</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">外护套橡胶管与电较密封紧固,用紫铜</span><span style="font-size: 14pt;" lang="EN-US">T3</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">材质的紫铜卡</span><span style="font-size: 14pt; color: #333333; font-family: 宋体; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体;">箍(每端两个)</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">在专项使用设备上挤压紧固,美观无磁性,密封效果好,使用寿命长。</span><span style="font-size: 14pt;" lang="EN-US"></span></p> <p class="MsoNormal" style="margin: 0cm 0cm 0pt; text-indent: 28pt; line-height: 25pt; mso-line-height-rule: exactly; mso-char-indent-count: 2.0;"><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman"; mso-no-proof: yes;">④</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">软体铜导线是用漆包线在专项使用数控绕线机上分层绕制而成。柔软、弯曲半径小;不易折断,因每根漆包线之间绝缘,传导电流无表面集肤效应,与其它同截面水冷电缆相比,通过相同的电流时,发热量小;电能传输效率高。用漆包线做水冷电缆的导线,可以提高水冷电缆的使用寿命。因水冷电缆的导线长期浸泡在水中,工作环境十分恶劣。以前我们用铜裸线做水冷电缆,当水冷电缆使用一段时间后,打开电缆外套,就会看到导线表面有一层绿色铜锈。后来我们改用漆包线做水冷电缆,因漆包线有漆膜保护层,它能起到防腐作用,耐腐蚀防锈能力强;据用户反映,我们用漆包线做导线制造的水冷电缆,其使用寿命是铜裸线的</span><span style="font-size: 14pt;" lang="EN-US">4</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">倍。</span><span style="font-size: 14pt;" lang="EN-US"></span></p> <p class="MsoNormal" style="margin: 0cm 0cm 0pt; text-indent: 21pt; line-height: 25pt; mso-line-height-rule: exactly; mso-char-indent-count: 1.5;"><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman"; mso-no-proof: yes;">⑤</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">进出水咀与电较加密封圈后活丝扣连接,折卸方便,更换容易。</span><span style="font-size: 14pt;" lang="EN-US"></span></p> <p class="MsoNormal" style="margin: 0cm 0cm 0pt; text-indent: 35pt; mso-char-indent-count: 2.5;"><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman"; mso-no-proof: yes;">⑥</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">我公司生产的单晶硅炉用的水冷电缆有三种规格型号:</span><span style="font-size: 14pt;" lang="EN-US">a.108×5.0 </span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">型(软体导线</span><span style="font-size: 14pt;" lang="EN-US">108mm<sup>2</sup></span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">,电缆总长度</span><span style="font-size: 14pt;" lang="EN-US">5m</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">)</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">;</span><span style="font-size: 14pt;" lang="EN-US">b.SLD200×5.0 </span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">型(软体导线</span><span style="font-size: 14pt;" lang="EN-US">200mm<sup>2</sup></span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">,电缆总长度</span><span style="font-size: 14pt;" lang="EN-US">5m</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">)</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">,此型号较常用,承载电流:</span><span style="font-size: 14pt;" lang="EN-US">I≥2000A</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">;</span><span style="font-size: 14pt; mso-hansi-font-family: 宋体;" lang="EN-US">c.</span><span style="font-size: 14pt;" lang="EN-US">SLD250×5.0 </span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">型(软体导线</span><span style="font-size: 14pt;" lang="EN-US">250mm<sup>2</sup></span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">,电缆总长度</span><span style="font-size: 14pt;" lang="EN-US">5m</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">)</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">。</span><span style="font-size: 14pt;" lang="EN-US">d.</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">电较安装平面尺寸:宽</span><span style="font-size: 14pt;" lang="EN-US">×</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">长</span><span style="font-size: 14pt;" lang="EN-US">×</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">厚</span><span style="font-size: 14pt;" lang="EN-US"> = 54mm×85mm×20mm </span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">;</span><span style="font-size: 14pt;" lang="EN-US">e.</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman"; mso-hansi-font-family: "Times New Roman";">电较与设备连接孔直径尺寸</span><span style="font-size: 14pt;" lang="EN-US">2—Φ12.5</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">;两孔中心距</span><span style="font-size: 14pt;" lang="EN-US">30mm</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">、</span><span style="font-size: 14pt;" lang="EN-US">40mm</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">、</span><span style="font-size: 14pt;" lang="EN-US">50mm</span><span style="font-size: 14pt; font-family: 宋体; mso-ascii-font-family: "Times New Roman";">三  </span><span style="font-size: 14pt; font-family: 宋体;">种。我公司可根据用户需要设计生产各种有特殊要求的水冷电缆。<span lang="EN-US"></span></span></p>
洛阳正奇机械有限公司单晶炉水冷电缆事业部 > 铝产品 > 供应单晶炉水冷电缆3
