主营:6061+7075+2A11+7072+高等03+1A80+1A50+1080
上海
面议(大量采购价格面议)
<p><span style=“FONT-SIZE: x-large“>5052</span><a href=“http://member.alu.cn/view/1975808.htm“ target=“_blank“><span style=“FONT-SIZE: x-large“>铝板</span></a><span style=“FONT-SIZE: x-large“>为AL-Mg系</span><a href=“http://member.alu.cn/view/2095402.htm“ target=“_blank“><span style=“FONT-SIZE: x-large“>合金铝板</span></a><span style=“FONT-SIZE: x-large“>,是应用较广的一种</span><a href=“http://member.alu.cn/view/1304169.htm“ target=“_blank“><span style=“FONT-SIZE: x-large“>防锈铝</span></a><span style=“FONT-SIZE: x-large“>,这种合金的强度高,特别是具有舒缓劳累强度:塑性与耐腐蚀性高,不能热处理强化,,在半冷作硬化时塑性</span><a href=“http://member.alu.cn/view/2579633.htm“ target=“_blank“><span style=“FONT-SIZE: x-large“>尚好</span></a><span style=“FONT-SIZE: x-large“>,冷作硬化时塑性低,耐腐蚀好,焊接性良好,可切削性能不良,可抛光。。 </span></p>
<p><a class=“ pic-handle“ title=“查看图片“ href=“http://baike.baidu.com/image/b3508d13c2bb15bb6438db26“ target=“_blank“></a><a href=“http://member.alu.cn/image/b3508d13c2bb15bb6438db26“ target=“_blank“></a></p>
<p> </p>
<p class=“pic-info“><span style=“FONT-SIZE: x-large“>5052铝板图片</span></p>
<h2 class=“headline-1 bk-sidecatalog-title“><a name=“2“></a><span class=“headline-content“><span style=“FONT-SIZE: x-large“>二、5052铝板的应用范围</span></span></h2>
<p><span style=“FONT-SIZE: x-large“> 5052铝板用途主要用于要求高的可塑性和良好的焊接性,在液体或气体介质中工作的低载荷零件,如邮箱,汽油或润滑油导管,各种液体容器和其他用深拉制作的小负荷零件:线材用来做铆钉。也常用于交通车辆、船舶的钣金件,仪表、街灯支架与铆钉、五金制品、电器外壳等。 </span></p>
<h2 class=“headline-1 bk-sidecatalog-title“><span class=“headline-content“><span style=“FONT-SIZE: x-large“>三、5052铝板的化学成份:</span></span></h2>
<p><span style=“FONT-SIZE: x-large“> 铝 Al :余量 ;硅 Si :0.25; </span></p>
<p><span style=“FONT-SIZE: x-large“> 铜 Cu :0.10 ;镁 Mg:2.2~2.8; </span></p>
<p><span style=“FONT-SIZE: x-large“> 锌 Zn:0.10; 锰 Mn:0.10; </span></p>
<p><a name=“4“></a><span class=“headline-content“><span style=“FONT-SIZE: x-large“>四、5052铝板的力学性能</span></span></p>
<p><span style=“FONT-SIZE: x-large“> 抗拉强度(σb ) :170~305MPa </span></p>
<p><span style=“FONT-SIZE: x-large“> 条件屈服强度 σ0.2 (MPa)≥65 </span></p>
<p><span style=“FONT-SIZE: x-large“> 弹性模量(E): 69.3~70.7Gpa </span></p>
<p><span style=“FONT-SIZE: x-large“> 退火温度为:345℃。 </span></p>
<h2 class=“headline-1 bk-sidecatalog-title“><span class=“headline-content“><span style=“FONT-SIZE: x-large“>五、5052铝板的表面质量</span></span></h2>
<p><span style=“FONT-SIZE: x-large“> 1、表面不允许有裂纹、腐蚀斑点和硝盐痕迹。 </span></p>
<p><span style=“FONT-SIZE: x-large“> 2、表面上允许有高层度不超过缺点所在部位壁厚公称尺寸8%的起皮、气泡、表面粗超和局部机械损伤,但缺点非常大高层度不能超过0.5mm,缺点总面积不超过板材总面积的5%。 </span></p>
<p><span style=“FONT-SIZE: x-large“> 3、允许供货方沿型材纵向打光至表面光滑。 </span></p>
<p><span style=“FONT-SIZE: x-large“> 4、其他要求:有需求方和供货方自己拟定。 </span></p>
<h2 class=“headline-1 bk-sidecatalog-title“><span class=“headline-content“><span style=“FONT-SIZE: x-large“>六、5052铝板焊接焊条型号</span></span></h2>
<p><span style=“FONT-SIZE: x-large“> 5052铝板可用ER5356焊条焊接,焊接以后能满足5052铝板的力学性能。5356的化学成分:Si:0.25; Fe:0.40 ;Cu:0.10;Mn:0.05-0.20; Mg :4.5-5.6; Cu:0.02--0.20; Zn:0.10- 0.20 ; Ti:0.06--0.20 ; Al:余量;5336含镁量高一些。 </span></p>
<h2 class=“headline-1 bk-sidecatalog-title“><span class=“headline-content“><span style=“FONT-SIZE: x-large“>七、5052铝板系列和1060铝板系列的区别</span></span></h2>
<p><span style=“FONT-SIZE: x-large“> 硬度:</span><a href=“http://member.alu.cn/view/2943591.htm“ target=“_blank“><span style=“FONT-SIZE: x-large“>1060铝板</span></a><span style=“FONT-SIZE: x-large“>的抗拉强度为 110-130之间,而5052系列的抗拉强度则达到了210-230之间也就是说5052的硬度比1060的硬度高高标准。 </span></p>
<p><span style=“FONT-SIZE: x-large“> 延伸率:1060系列的延伸率为5%,而5052系列的延伸率达到了12-20%之间,也可以这样认为,在5052系列比1060硬高标准的情况下,延伸率也提高了200%左右。 </span></p>
<p><span style=“FONT-SIZE: x-large“> 化学性能:1060为</span><a href=“http://member.alu.cn/view/2949455.htm“ target=“_blank“><span style=“FONT-SIZE: x-large“>纯铝板</span></a><span style=“FONT-SIZE: x-large“>,5052为合金铝板,在特殊环境下5052耐腐蚀更好一些。 </span></p>
<h2 class=“headline-1 bk-sidecatalog-title“><span class=“headline-content“><span style=“FONT-SIZE: x-large“>八、相关产品标准</span></span></h2>
<p><span style=“FONT-SIZE: x-large“> 铝板带国家标准(GB/T 3880-2006),适用于铝合金板带材料的统一标准。</span></p>
<p> </p>
