主营:
山东 济南
电议元/台(大量采购价格面议)
设备特点 Equipment Features
◆用于平板太阳能边框型材的45° 、 90°切割加工
◆原装进口硬质合金锯片,加工精度高,耐用度高。
◆高精度主轴使锯片转动稳定。
◆气液阻尼缸实现调速均匀,进给平稳
◆能够一次切出所需型材长度
◆Used for cutting Flat Plate Solar frame profile at 45°、 90°.
◆Imported carbide saw blade give accurate processing and high endurance.
◆Saw blade rotate smoothly due to high accurancy main spindie.
◆Uniform speed feeding and smoothly motion due to airdraulic damping cylinder.
◆One time processing can cut off the required length.
主要规格及技术参数 Main Specification and Technical Parameter
电源 |
Power supply |
380V 50HZ |
电机功率 |
Saw-head motor power |
2×1.5kw+0.55kw |
转速 |
Cutting motor rotary speed |
2800r/min |
工作压力 |
Operation air pressure
0.5MPa-0.8MPa |
锯切长度 |
Cutting length |
Max3700mm Min 400mm(外摆) Min550mm(内摆) |
锯切宽度 |
Cutting width |
Max 120mm 45° Max 165mm 90° |
锯切高度 |
Cutting height |
Max 120mm 45° Max 200mm 90° |
锯切角度 |
Cutting angle |
90°45° |
锯片规格 |
Blade specification |
Φ450mm×4mm×Φ30mm Z=120 |
外形尺寸 |
Dimension |
4500mm×1700mm×1400mm |
重量 |
Weight |
1500kg |
